What are good o2's to run.
Old Apr 25, 2005 | 08:02 AM
JRracing's Avatar
Default What are good o2's to run.
I have put new headers on & thought about putting in new o2's since I have been running leaded gas through the old ones. Is the boasch o2's any good, that is all the parts stores sell around here. I don't think I'll be running leaded gas through them any more. But maybe when new heads go on. How about those denso's are they good?
Old Apr 25, 2005 | 08:04 AM
ddelallata's Avatar
Go buy new ones at the dealer and stay away from Bosch 02s.
Old Apr 25, 2005 | 08:11 AM
tim99ws6's Avatar
anyone got a part number for the corvette oxygen sensors that can be used for our front 02's?
Old Apr 25, 2005 | 08:39 AM
GuitsBoy's Avatar
I have bosch and those too are going bad on me again. I would suggest looking into the denso corvette rear o2's for use in the f-body front locations. Densos also seem to be far more lead tolerant, but theyll eventually die from running too much leaded gas too.
Old Apr 25, 2005 | 10:46 PM
JRracing's Avatar
Is this the right #'s 234-4025 L 234-4087 R Are these correct denso's. Are the wires longer than stock wires like the bousch 13444's? I checked on oem O2's they were 150.00 retail, thats to much.
Old Apr 25, 2005 | 10:51 PM
Nasty Hawk's Avatar
I actually switched to the bosch corvette rears 02's to put in my fronts cause my slp extensions were failing everything up and the vette ones didnt work for me either. I am probly going to do a closed loop on them.
Old Apr 25, 2005 | 11:42 PM
JRracing's Avatar
I don't know that mine are bad. When I went to the dyno last time & got it tuned, the A/F gauge on the dyno was not working properly so we could'nt get a correct reading. But the plugs are pretty white when I took them out yesterday. I also have ran racing gas through it mixxed 50/50 with 93oct. I also just installed FLP Lt's & figured why not. Need GOOD advice.
Old Apr 25, 2005 | 11:47 PM
blkZ28spt's Avatar
What's wrong with the Bosch O2's??
My original O2's got fouled to all heck and after some minor searching I realized I should be running O2's made for the rear C5 bank. Ended up with Bosch part #13111. I put them in and my horrid problems went away immediately. Am I going to end up replacing them with something else? I havn't happened across this claim before.
Old Apr 26, 2005 | 02:07 AM
JRracing's Avatar
I hear ther not very good. They don't last long I guess.
Old Apr 27, 2005 | 09:10 PM
JRracing's Avatar
I just got some denso's from spark plug.com for about 60 bocks. We'll see how they do when they get here.
Old Apr 28, 2005 | 02:19 AM
z-ya's Avatar
denso=good,If you get the vette rear ones you get long wires and high amp heaters.
Old May 2, 2005 | 08:12 PM
Cstick's Avatar
Cars with Rear Vette O2s in front. Are the wires long enough for PC long tubes on Z28? Thanks guys
Old May 2, 2005 | 08:15 PM
blkZ28spt's Avatar
Wires should be plenty long for any header. I had to bundle extra wire up with zip ties on both sides. (jet-hots)
Old May 3, 2005 | 09:31 AM
GuitsBoy's Avatar
Same here. I cant imagine it not reaching any header.
