Pacesetter Longtube Ground Clearance, and Y Pipe Info
Hey guys i was wondering how the ground clearance is on the pacesetters? My car is lowered, but im not sure with which kit, but its pretty low, but i just wanted to know if the pacesetters fit up pretty nice.
ALso i heard there y pipe is not all that great, so would i be better off going with another y-pipe, such as a TSP or has anyone had good results with the pacesetter ones. Thanks Alot
JacobK
JacobK
My Pacesetter collectors where about half an inch below the floorpan on my car. They look to be about even with the K-member. The issue for me was the drivers side pipe that has to run under some floor pan support bracket about a foot after the headers. The headers fit very nice and I would recommend them.
mine are not too bad, they hang just below my subframes, but hardly at all. I think they tuck up real nice. you just take your time and it might take some lovin when it comes to the y-pipe.
I have the Pacesetter headers with their offroad y. I also have a poly motor mount on the drivers side that I would recommend. As you can see from this pic, my car is lowered an inch and there's plenty of room with the pacesetter y-pipe. I like it.
get the pacesetter headers, their ory and poly motor mounts and never look back. my car is dropped about 1.5 inches, or so. i have 3.25 inches of clearance at the lowest spot on the ypipe, i have no issues with it banging at all wtih the poly mounts, its a great kit IMO, go for it
Where can i get the poly motor mounts from? Im gonna be buying the headers and ORY from SPeed Inc, since its locally, and i dont have to worry about shipping..thanks
JacobK
JacobK
what if i dont get them? do i absolutely need them? also how much do they run usually? how do u guys think it will sound with the borla and ory, i hope loud...haha
yeah it will be loud, little raspy but loud.
u dont HAVE to have them, but it helps keep everything steady, they usually go for 50 bucks. if not you may have to get a different y that doesnt fit so tight, but then u lose ground clearance. get a tape measure and measure the distance from the kmember bottom to the ground, then ill let u know how close it is to my set up
I have the Pacesetter LT's and ORY... both fit awesome and I have enough ground clearance to not worry. The car is pretty low in the front as well (WS6FirebirdTA00) seen it at the AutoFair a couple of weekends ago. The only time I've really got hung up on anything was coming out of a restaurant that had a VERY steep exit angle compared to the street and I had a 260lb friend in the car with me. I could hear/feel the collectors rub pretty hard against the pavement but it didn't damage anything. Regular street driving is the same for me v/s stock exhaust.
Here is a shot of mine from AF to give you an idea of how low it is...
im gonna go take some pics of my car and under it to show you, ive hit my collectors one time on a speed bump but i stopped right on the otehr side of it and sat the car down on the bump, it almost made me cry, lol jk but it didnt do any damage really jsut a little dent, dime size.
let me get them pics
Originally Posted by JacobK
ok i just went out and measured, i think from the ground to the stock Y i have about 4 inches of ground clearance.
got a pic with a tape measure under the pipe, its 3 inches tall, and i hve one showing my front tire so u can see how low it is in relation to yours
