ASP Pulley Install - Pics Too!
Old May 14, 2005 | 05:29 PM
Grimes's Avatar
Default ASP Pulley Install - Pics Too!
Well, just got the pulley on there. Went pretty smooth. A couple of tips:
-Get a breaker bar and a long piece of pipe to get the old crank bolt out. I did this and got it off in 10 minutes!
-the 5 ton 2/3 jaw puller from sears is just the right lengh & size. Use a socket as a spacer to get the last half of the stock pulley off.
-I torqued the new bolt with a 250lb-ft torque wrench. The only damn way to get to the higher torque values was to press on the wrench with my foot, and "leg press" the wrench. lol.
-I got a realtively new ASP pulley (May 05) and it slid on with no problem, allowing me to get 3-4 threads of the old bolt, so that I could safely use it to seat the ASP pulley.
Attached Thumbnails ASP Pulley Install - Pics Too!-pulley_compare.jpg   ASP Pulley Install - Pics Too!-asp1.jpg   ASP Pulley Install - Pics Too!-asp2.jpg
Old May 14, 2005 | 05:31 PM
blkZ28spt's Avatar
FYI: The new crank bolts are supposed to be stretched into place, something like 110*. I didn't get 110* on mine, maxed out my torque wrench at 250 lb-feet and figured it was on there pretty good. lol
Old May 14, 2005 | 05:45 PM
Grimes's Avatar
hey, thanks for the heads up, but I had an ARP one so I didn't do the angle measurement
