Free Mods: Worth it?
Old May 21, 2005 | 01:05 AM
BottleRocket's Avatar
Default Free Mods: Worth it?
I wanted to know if all of the free mods were worth doing. Meaning ported MAF, !egr, coolant bypass, FRA mod, etc. Im thinking about doing them tomorrow but I dont know if I want to because it might just be wasted effort.
Old May 21, 2005 | 04:45 AM
jrp's Avatar
jrp
SN95 Director
not to me honestly.
Old May 21, 2005 | 05:03 AM
why not? i was kinda looking for a reason. ive heard mixed reviews but i dont know what to believe
Old May 21, 2005 | 11:17 AM
jblack245's Avatar
Check this out
http://www.gmhightechperformance.com...ls1/index.html
Old May 21, 2005 | 11:30 AM
blkZ28spt's Avatar
Don't port the MAF. ESPECIALLY if you have an auto. Descreen it at the most, being carefull of the wires.
Ho can they NOT be worth it? They are free.
Old May 21, 2005 | 11:54 AM
12stones's Avatar
dont port the maf, other wise do the coolent bypass, fra, and !egr (if its a 98-00) i think all of those are worth it, and hell its FREE! value dosn't get any better
Old May 21, 2005 | 11:56 AM
blkZ28spt's Avatar
BTW: It's not "!FRA", it's just FRA. The "!" signifies that you removed or disabled it.
Descreen MAF, FRA, !AIR and !EGR, home ported TB with bump stop mod......
Old May 21, 2005 | 12:15 PM
12stones's Avatar
corrected
Old May 21, 2005 | 12:55 PM
USMARINE1108's Avatar
This may be a stupid question, but why only !egr if it's a 98-00?
Old May 21, 2005 | 12:58 PM
there isnt EGR on the 01-02
Old May 21, 2005 | 01:01 PM
blkZ28spt's Avatar
I think he's asking why he didn't list !AIR as well. Go ahead and rip the air system out too.
Old May 21, 2005 | 01:12 PM
8-Pack's Avatar
Originally Posted by jblack245
Good article but I bet most of the gains were from the ported tb and FRA.
Old May 21, 2005 | 02:27 PM
you dont think the !EGR mod does alot for the car? that thing looks like it can be quite obstructive
Old May 21, 2005 | 02:28 PM
blkZ28spt's Avatar
It makes the engine bay look neater, and makes it easier to work on. Removes a small amount of weight as well.
Old May 21, 2005 | 05:10 PM
JarredWS6's Avatar
the only free mod i noticed a difference on was removing the hood baffles on my WS6.
Old May 21, 2005 | 06:05 PM
blkZ28spt's Avatar
Free mods aren't a matter of noticing a difference. You probably won't be able to feel a difference until it's on the order of about 10 rwhp. Free mods fall under the "every little bit helps" category.
Old May 21, 2005 | 07:50 PM
jrp's Avatar
jrp
SN95 Director
bingo.
Old May 21, 2005 | 07:55 PM
Diolar Magnum's Avatar
RIP April 14, 2008
From: the land where cars repeatedly hit my bumper when I'm in the store...
big fan of the FRA right here
Old May 21, 2005 | 09:56 PM
Another_User's Avatar
Porting the MAF is perfectly fine IF you can tune for it. Otherwise, leave it alone. !FRA works well, no ill effects here. !EGR works well, especially on cammed cars with a lot of overlap, however it is likely you will need to adjust your spark table. The TB stop mod is probably a waste of time. The TB coolant bypass is probably ok, but I wouldn't do it. You end up with marginally more hp, if any, and the possibility of your TB icing up if you are in a cold enough area. !AIR is not a hp mod. Any mod that removes weight has some purpose though.
Old May 21, 2005 | 10:52 PM
dogger's Avatar
I did the free mod's and as stated earlier fra and ported throttle body mod were the ones that had a noticable difference. I did do the throttle body bypass because I only drive my car when it's nice but didn't notice much diffence except on cool night's.just my 2 cents
