160* Stat.... Um... yeah
Old Jun 2, 2005 | 04:11 PM
Y2K SS's Avatar
Default 160* Stat.... Um... yeah
Well I know there has and always will be a debate on the need for a 160* Stat. Well just got mine and threw it in. For you guys out there who don't know (I just found out) the stock gauges are crap. All this time my temp gauge would run at around 210. But my oil temp (Auto Meter)gauge would always fluctuate and sometimes go up to high 240s. On my HPTuner my car water temp would get as hot as 230's. Since putting in my 160 stat my temp (via HPtuner) has not exceeded 190 even though my water temp gauge on the car still says around 210. Where I notice it the most is on my oil temp gauge. My oil temp has not gotten over 210 since the thermostat change. That in itself is why I'm giving it .
Old Jun 2, 2005 | 04:22 PM
~JOSHUA's Avatar
Yeah, 1998 was the last year for a functional water guage. after that they are all dummy lights...
Old Jun 2, 2005 | 06:53 PM
ArcticZ28's Avatar
Yep... my guages actually showed the difference... consistently runs ~15 deg. cooler.
Old Jun 2, 2005 | 07:45 PM
Frosty's Avatar
I still think that's ******* retarded.
Old Jun 2, 2005 | 08:38 PM
ArcticZ28's Avatar
What is?
Old Jun 2, 2005 | 08:39 PM
Frosty's Avatar
Originally Posted by ArcticZ28
What is?
GM using a dummy gauge for the water temp
Old Jun 2, 2005 | 08:41 PM
ArcticZ28's Avatar
Truth.
Old Jun 2, 2005 | 08:43 PM
ArcticZ28's Avatar
Sorry, just had to post again so that my post count wasn't sitting at the triple 6's
Old Jun 2, 2005 | 08:44 PM
Frosty's Avatar
Old Jun 2, 2005 | 09:13 PM
ArcticZ28's Avatar
haha, yeeep, that's how i roll
Old Jun 2, 2005 | 09:28 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Just an FYI.
The 230 temps are due more to stock fan settings than the stock stat. You can get even the stock stat to maintain 19X temps no problem with the proper fan tuning.
The 160 stat will still heat up if idling though traffic with stock fan settings.
Old Jun 2, 2005 | 10:03 PM
ArcticZ28's Avatar
Right on... you gotta modify the fan's to come on earlier... I believe most used ~180 for the first fan and high 180's for the second fan.
Old Jun 3, 2005 | 03:39 AM
Y2K SS's Avatar
Well I got news for you fellas... Horist dropped my fans for me when I was learning to use my HPTuner and it dropped about 10*. He told me to get a lower stat. I was in traffic today and it only got (oil temp) to 215* or so. Sorry my bad I thought I mentioned the fact that I used the HPTuner ot adjust the fans.
Old Jun 3, 2005 | 06:51 AM
RPM WS6's Avatar
That's odd....wonder what he set your fans too?
I was able to get my stock stat to run coolant temps in the mid-190 range (confirmed via scanner) no problem with lower fan settings (stock stat starts to open around 180* or so). A 160 stat should be able to run as cool as ~172 (+/- a couple degrees) with proper fan settings.
Old Jun 3, 2005 | 10:19 AM
Bad Blu Formula's Avatar
Yeah, but running those fans ALL the time is not good for the motors on them. Gotta find the equilibrium.
Old Jun 3, 2005 | 10:29 AM
Semp3rFi's Avatar
wow, thats really stupid... So.. I guess its time to go get a real one for me now.. lol
Old Jun 3, 2005 | 10:38 AM
Frosty's Avatar
That's what I'm doing soon...only because I'm a control freak. I like to know what's going on with my motor at all times(even though I know the car isn't overheating or anything)
Old Jun 3, 2005 | 11:54 AM
speed~deelr's Avatar
The cars weren't the only "idiot" lighted water temped vehicles.
My Dad's Duramax 3500 is also idiot lighted. The Water temp sits at 210* as soon as actaul water temp hits 190 or so, and stays at 210 untill the water temp hits 240 then it heads up towards the red.
Thanks GM. (Atleast GM has working oil pressure gauges... Unlike Dodge and Ford.
Merrick
Old Jun 3, 2005 | 05:49 PM
RPM WS6's Avatar
No need to tun them all the time. I can get the stock stat to cycle temps between 196-207 with the fans cutting on and off as they should. When cruising, they usually stay around 194-196 without the fans even coming on. Only time the fans are needed is when idling or stuck in heavy traffic.
Some like to run their temps lower though, for that you need the 160 stat.
Old Jun 4, 2005 | 03:54 PM
Y2K SS's Avatar
You know.... I guess its because I have a cammed car that I got such stupid temps. Cammed guys run hotter. All this time I thought my oil temp sender mounted in the oil filter adapter was mounted to close to my LTs so I thought I was getting a false reading. Not till I put in the stat did I realize my gauge is dead on. Scary because my oil temp reached 240's at times and I know oil breaks down a hell of a lot sooner than that.
