Kooks header gasket leak
Old Jun 5, 2005 | 07:09 AM
axer's Avatar
Default Kooks header gasket leak
I just installed a new set of Kooks on my Vette. I ordered the
LS6 gasket, but when I put them on my FFHP LS6 heads, the gasket
blocked about 3/16" of the top of the exhaust port, so I ended up
using the gasket that came with the headers. I used ARP studs and
torqued the headers to 18 ft.lbs.
Because the stock Z06 exhaust is much easier to install on a lift,
I had a local shop finish the exhaust. When I picked up the car they
told me I have an exhaust leak and I should have used the GM gaskets.
Here is my problem.....The bottom "V" bracket was very tight and
pulled the collectors together. I think this is my problem because the
headers are "pryed" away from the heads. I think if I use the GM gasket
the problem might be worse. I am going to pull the bracket off and see
if I can get less tension on the headers and see if that works. If not,
does anyone make a thicker gasket that might seal better?
Thanks!
AXER
Old Jun 5, 2005 | 07:50 AM
AKRA's Avatar
When I installed my Hooker Long Tubes, I made the same mistake by using the ones that cam with the headers. I replaced them with the stock GM Gaskets from the local chevy dealer and I've had no problems. That was close to two years ago.
Good luck,
Al
Old Jun 5, 2005 | 09:45 AM
WILWAXU's Avatar
yup. Grab a set of stock replacements from your local GM dealer.
