Help with Headers/check engine light
Old Jun 5, 2005 | 03:51 PM
ls12000's Avatar
Default Help with Headers/check engine light
Just had kooks L/T headers installed on my 00 T/A. The car ran good for a few days then the Service Engine Light came on. I took it to Auto Zone for a quick diagnostic test and it read that itwas the catalytic convertor. I just had a new one installed about three months ago before my headers. One of the guys said that my o2 sensors need to be connected and if i had them in the fornt or back. Can anyone explain what the problem might be Any help/suggestions would be helpful thanks. i have 1 3/4 Long tubes with magnaflow catted y-pipe with o2 connectors
Old Jun 5, 2005 | 04:00 PM
Z28Venom's Avatar
You have LT headers...
What is the rest of your exhaust? Catted y-pipe or ORY? We need a little more info.
Old Jun 5, 2005 | 04:02 PM
ls12000's Avatar
Default reply
1 3/4 L/T with high flow magnaflow catted y-pipe with o2 connectors
Old Jun 5, 2005 | 04:05 PM
Z28Venom's Avatar
Are you running O2 sims, or is everything hooked up just like stock just with aftermarket parts?
Old Jun 5, 2005 | 04:37 PM
ls12000's Avatar
Default reply
I believe i have o2 sims
Old Jun 5, 2005 | 05:18 PM
davered00ss's Avatar
Moderator
Either get O2 sims or use LS1 edit to delete the rear O2's.
Old Jun 5, 2005 | 07:14 PM
ls12000's Avatar
Default Reply
do u know how much the o2 simulators are?? Or if i decide to delete the rear o2's will it hurt the car and still pass inspection
Old Jun 5, 2005 | 08:45 PM
shouldaboughttheZ's Avatar
Look in the for sale section. i have seen them there for $50 on up.
If you decide to go the delete way, which is what I ended up doing, it does not hurt the car at all.
Where are you at in Houston? I could recommend a tuner to do this.
Old Jun 5, 2005 | 08:59 PM
ls12000's Avatar
Default reply
iam in the Nw area by 290 and Bltwy 8 That check engine light is getting to me
Old Jun 6, 2005 | 04:52 PM
Scully's Avatar
the o2 sims are like 85.00 brand new. i don't see spending the extra 65.00 dollars on a mail order if headers is all you have done to the car.
Old Jun 6, 2005 | 04:53 PM
Scully's Avatar
oh i forgot to tell you, speed inc. sells the sims
Old Jun 6, 2005 | 06:27 PM
Cefiro's Avatar
Since you have LT's a tune would prolly be a good idea, you will be running a little rich right now. I put that $85 toward a tune, and just have them delete the codes. You should be able to find many tuners in the Houston area.
Old Jun 7, 2005 | 01:47 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
1- find out what the code is and do everything to resolve it.
2- get used to your SES light coming on.
Old Jun 7, 2005 | 08:17 PM
ls12000's Avatar
Default replies
Thanks for all the replies They helped out lots I now have more knowledge in what i need to do to fix the problem and more of a basic knowledge of Headers Thanks again
