a good coolent
Old Jun 8, 2005 | 11:11 PM
ozzykicks2002's Avatar
Default a good coolent
I was talking to the dealership to day about some stuff and started to talk about my car and he told me to get that dex-cool collent thats in the car now out of it ASAP!! he said that its the worst thing that chevy has ever come up with, it turns corrosive appently. So I drained it and filled it with water and ina few more days im going to drain that and do it again. So I want to get a good coolent for it. any recomendation?
Old Jun 8, 2005 | 11:13 PM
Roarin_8's Avatar
I haven't heard anything about that. Anyone else here?
Old Jun 8, 2005 | 11:25 PM
http://www.consumeraffairs.com/autom...m_dexcool.html
take a look at this
Old Jun 8, 2005 | 11:36 PM
Roarin_8's Avatar
Hmmm I'll get some insight from TTP.
hotrod04's Avatar
Evans cooling system is the only way to go. www.evanscooling.com
Old Jun 8, 2005 | 11:41 PM
2xLS1's Avatar
And everyone knows that dealership service writers are all the sharpest tacks in the pile. Don't let the radiator get low so air is in it and change your Dexcool every couple of years and it will be fine.
Old Jun 8, 2005 | 11:49 PM
Stroker 1500's Avatar
Most of the times i have heard of people having problems with dex cool is from improper use. Like using tap water, thats a big no no and you will have problems. You have to use distilled water
Old Jun 9, 2005 | 10:53 AM
So If you just change the dex cool more foten then they recommend your good? Where can you get dex cool? what is the best way to have the system flushed as well?
Old Jun 9, 2005 | 11:28 AM
2xLS1's Avatar
I buy genuine Texaco Dexcool at WalMart.
Old Jun 9, 2005 | 01:36 PM
whats the best way to flush the system? have a shop do it? or can you do it your self?
Old Jun 9, 2005 | 03:57 PM
Scully's Avatar
fellas i've heard of this problem. a couple of years ago their was an article (in gm high tech i believe) that talked about a guy who had a newer model s-10 and the dex cool (orange coolant) corroded his block so bad the freeze plugs started leaking. also i believe the truck was only like a year or two old. shouldn't happen in that amount of time. i flushed my z and switched it to prestone. the green kind. if you do this MAKE SURE the engine is flushed really good. no orange left in there. temps have been great and everything has worked properly.
Old Jun 9, 2005 | 06:06 PM
WILWAXU's Avatar
I use Prestone pre-mixed Dexcool in my car.
Old Jun 9, 2005 | 07:37 PM
Whats the best/safest way to flush my system and get some new stuff in it. and what kind of coolent should I go with?
Old Jun 9, 2005 | 08:07 PM
Scully's Avatar
Default coolant flush
okay first you need to go to an auto parts store or wal mart and pick up the prestone coolant flush. it's in a minature yellow jug. drain the collant from the cars or trucks system. pour in the prestone coolant flush and fill with water. start car with defrost or heat on. let idle for like 5-10 mins. make sure the thermostat opens so the block will be cleaned also. after you let the coolant flush make its cycle, drain the system again. close ****, and fill with your coolant and water. i mixed mine like 2 part coolant to 1 part water.
Old Jun 9, 2005 | 09:27 PM
Mikriman's Avatar
Default a Good coolant
I just had my radiator flushed and they said Dex sludges up. So they put some other stuff in-can't remember what it was. Something like "G05"
Old Jun 10, 2005 | 12:04 PM
So is the whole hose thing a good thing to do? or just buy the collent flush fluid?I just dont wanna ruin anyhting
Old Jun 10, 2005 | 12:50 PM
bump So i guess my question is should I stay with dex cool or switch to something else?
Old Jun 10, 2005 | 01:41 PM
DONAIMIAN's Avatar
I run distilled water and watter wetter to battle the texas heat.
Old Jun 10, 2005 | 02:06 PM
Tranzor's Avatar
Amsoil makes a good propylene glycol coolant as well that is Dexcool compatible... it is kind of pricey, but I'm going to give it a go next time I flush the coolant in my car.
If any of you guys are interested in giving it a try, let me know... as an Amsoil dealer, I'll make sure to get the best price I can for fellow LS1TECH members. Feel free to PM me for more info and/or prices, including sales tax (if applicable) and shipping direct to your door.
Old Jun 10, 2005 | 07:34 PM
MetallicaMatt's Avatar
how do you get all of the air out of the system?
that can cause hot pockets and heat problems
