Tips for changing #8 spark plug.
Old Jun 21, 2005 | 08:03 PM
AronZ28's Avatar
Angry Tips for changing #8 spark plug.
Well I finally got around to changing the plugs. Except #8. I have followed Install University's write up on changing them, its a very good guide BTW. Well I ran out of daylight, so I'll be out there working on #8 tommorrow. I removed the AIR pipe and pushed the coil pack rail upwards to give myself some room. I tried their method of using a 1/2" swivel extension with no results. I couldn't get enough torque on the sucker to break it loose with tiny 1/4" ratchet that would fit back there. I tried using a 1/2" ratchet, but couldn't ever get the sucker in position and it was too big to work with back there. Right now my game plan is to go out there tommorrow and fiddle with the 1/2" ratchet and 1/2" extension and pray.
So how did you change your #8 plug? Can you get at the sucker better from underneath the car???(I doubt you could). How hard is it to remove that black plastic thing that is to the left and in the way?
Old Jun 21, 2005 | 08:06 PM
Mike K.'s Avatar
#8 I usually do from the bottom, its all about the right comination of tools other than that, use different sized socketz/wrenches until you get a good combo. #8 is easier from the bottom though. If you have stock manifolds and cats it may still be too hard to go from the bottom in which case you will need the right tools for you and some patience.
Old Jun 21, 2005 | 08:09 PM
DWillTA's Avatar
I change #8 from the bottom also. I think the black plastic thing you speak of is the AC Evaporater. Also headers make it better believe it ir not. Hope that helps.
Old Jun 21, 2005 | 08:14 PM
Tally TransAm's Avatar
if you complete remove the coil pack rack youll have plenty of room to get it from the top
i use a 3/8 rachet+3/8 swivel extension+spark plug socket
Old Jun 22, 2005 | 08:14 AM
shouldaboughttheZ's Avatar
I used the install university write up as well, and ended up using the 1/4" ratchet and an adapter for the 3/8" socket. Worked great. I did it from the top also.
Old Jun 22, 2005 | 08:18 AM
Steve Burger's Avatar
LS1TECH Sponsor
Pull the coil packs and do it from the top. Once you get the back bolt out for the coil packs throw it as far as you can and never look back.
Old Jun 22, 2005 | 09:47 AM
AronZ28's Avatar
So can I get to it from under the car with the stock manifolds, cats, and y-pipe?
Old Jun 22, 2005 | 09:52 AM
josh99ta's Avatar
Sold The Fun Stuff :(
Yep. Also, its hard to break with a ratchet so I use the spark plug socket and a wrench to break it, then loosen it with the wrench or throw a ratchet on there (or a ratcheting wrench). I just installed headers and it freed up alot of room for a plug change also.
Old Jun 22, 2005 | 10:42 AM
MTN_Z's Avatar
Man do I ever hear ya about that back bolt on the coil packs. I chucked that thing who knows how far. But yeah ditto what everyone is saying by going from the top. Remove the whole coil pack assembly and you should have no problem with the swivel and socket. If you haven't ever removed the coil packs, bring a big bag of expletives with ya. I sure needed them.
Old Jun 22, 2005 | 10:57 AM
silver02Z's Avatar
Another vote for removing the coil packs...
kevin
Old Jun 22, 2005 | 11:39 AM
Stark's Avatar
Yep, pull the coil packs off and get it from the top!
Old Jun 22, 2005 | 12:27 PM
patSS/00's Avatar
I see from your profile you have a 99 - I believe you can't do those from underneath, due to the cat being in the way - it only works on 00+ cars.
Old Jun 22, 2005 | 12:46 PM
JMBLOWNWS6's Avatar
Get headers
Old Jun 22, 2005 | 12:56 PM
2000WS6Vert's Avatar
I had no problem doing this....as stated by those above....unbolt the coil packs and you should have no problem.
Old Jun 22, 2005 | 01:06 PM
Armageddon's Avatar
...with cheese.
Drop the motor...
Old Jun 22, 2005 | 05:38 PM
LS1TechRulez's Avatar
get headers....remove #8 plug from the bottom. if you still have stock manifolds then I would remove the coil pack (even thought that is a bitch) and muscle it from there.
Old Jun 22, 2005 | 05:41 PM
Dustin's Avatar
mine was done from the bottom...i even have stock manifolds, it took my friend awhile and he is pretty skinny, myself i couldnt get close to it.
Old Jun 22, 2005 | 09:33 PM
AronZ28's Avatar
Originally Posted by JMBLOWNWS6
Get headers
I wish, but I don't want to fool with it because of emmissions testing around here. Not to mention I don't have the $$$$.
Old Jun 22, 2005 | 09:43 PM
PhoenixLS6's Avatar
**** going through the bottom and removing the coil pack. I did it with a swivel ratchet and an extension. I had no prob, you can do it just be patient...
Old Jun 22, 2005 | 09:57 PM
Phoenix 5.7's Avatar
i removed the coil packs and never reinstalled it again (thunder kit). that one was a major PITA even with headers. i found a breaker bar worked better than a ratchet.
