What X-pipe is everyone running?
Old Jun 23, 2005 | 09:55 AM
NX_CaGEdApE00's Avatar
Default What X-pipe is everyone running?
2000 z28 m6 w/ slp lt's.?
Thanks
Old Jun 23, 2005 | 09:56 AM
SSmoked99's Avatar
I wanna know too..
input please
Old Jun 23, 2005 | 09:58 AM
777's Avatar
777
I'm running the TSP X, most prolly use the dr. gas
Old Jun 23, 2005 | 10:29 AM
where can i get and how much is the dr gas x-pipe and is it direct fit or do i need other
stuff as well
Old Jun 23, 2005 | 12:30 PM
josh99ta's Avatar
Sold The Fun Stuff :(
TSP since I bought their setup (incompetent exhaust shops around here). If you have a halfdecent shop anywhere near you I'd get the Dr. Gas X and have them fab a whole setup for you.
Old Jun 23, 2005 | 12:53 PM
blkZ28spt's Avatar
There are really only a few main setup types.
LS1 Speed and Texas Speed and Performance duals.
Dr Gas, possibly purchased with pipes in a "kit". Local exhaust shop put together.
I have seen some people with a Magnaflow X-pipe as well.
Old Jun 23, 2005 | 01:01 PM
BOONE's Avatar
Default x pipe
Ive seen several x pipes inside before welding them together, and the dr gas is the best quality, and looks like it would flow the best inside. IE smooth transition, clean, perfect, balanced, corners in the x. Most all others are inferior, and for Gods sake use mandrel bends or suffer. Once you look inside you will know you made the right choice. Not to knock anyones stuff but if you looked you would have to agree..
Old Jun 23, 2005 | 01:05 PM
Turo's Avatar
Heddman here
Old Jun 23, 2005 | 01:30 PM
LS69TA's Avatar
I had a Heddman on my 02 Z. Looked as good as the Dr. Gas that I have now, which is posted in the FOR SALE section if you need one.
Old Jun 23, 2005 | 02:03 PM
BOONE's Avatar
Default x pipe
Sounds like there might be a cheaper priced, quality unit!!?? Like to see one.
Cheap price good quality is always good...
Old Jun 23, 2005 | 02:07 PM
elite22xl's Avatar
i used an x pipe from sweet thunder, i dont really see any guys saying they use it, im sure there are better ones out there, but my buddy that did my system cut the x apart anyways to get it to fit so whatever i guess.
Old Jun 23, 2005 | 04:39 PM
Default How Much And What Exactly Is It?
wILL IT FIT MY 00 Z28 W/ SLP LTS. AND IS IT IN GOOD CONDITION.
DO YOU HAVE PICS
THANKS
Old Jun 23, 2005 | 04:53 PM
Default dr. gas
which kit would i get from dr. gas????
Old Jun 23, 2005 | 04:59 PM
DWillTA's Avatar
I am using a Magnaflow Tru-X transition. It is constructed almost like two separate pieces of steel were stamped into the X shape then they were welded together. Here is a pic of the outside. Sorry no inside pics.
