if i put a bigger pulley on...
Old Jun 24, 2005 | 12:41 AM
pdd's Avatar
pdd
Default if i put a bigger pulley on...
on my alt to slow it down, would that screw anything up?
Old Jun 24, 2005 | 02:38 AM
oange ss's Avatar
yes, if you already have an under drive crank pulley
Old Jun 24, 2005 | 07:19 AM
pdd's Avatar
pdd
i have the stock crank pulley on
Old Jun 24, 2005 | 08:48 AM
ty_ty13's Avatar
7 Second Club
y did you only replace the alt. pulley?
Old Jun 24, 2005 | 11:06 AM
pdd's Avatar
pdd
last year the plastic fan blew off it at high rpms and smahed my hood. so i figured a bigger pulley on the alt would slow i down alittle
Old Jun 24, 2005 | 01:03 PM
ty_ty13's Avatar
7 Second Club
hhmmm...thats odd
yeah... larger will slow it down... but you might have to raise your idle...
might that is..
Old Jun 24, 2005 | 01:05 PM
slowpoke96z28's Avatar
fix the fan, not the alternator . the only way the alternator would cause this is if its internal regulator was bad, and you'd have fried more stuff by now
Old Jun 24, 2005 | 01:06 PM
how high do you normally spin the engine?
Old Jun 25, 2005 | 10:22 AM
pdd's Avatar
pdd
shift light is set at 6500rpms
Old Jun 25, 2005 | 10:36 AM
P Mack's Avatar
Why don't you want an underdrive crank pulley?
Old Jun 25, 2005 | 10:54 PM
thats not going to spin the alternator fast enough to ruin it
Old Jun 26, 2005 | 09:55 AM
cyphur's Avatar
thats why guys run underdrive ASP crank pullies and the overdriver ASP alt pullies for big systems all the time without issue. it actually solves many problems.
however with a stock crank pully i don't see why this should be happening. sounds like something else is gonig on!
Old Jun 26, 2005 | 06:47 PM
pdd's Avatar
pdd
i have an ati super damper. when i went to install it the bolt heads were hitting the steering rack. so i didnt install it. maybe ill install it over the winter. back to the original question. will the larger alt pulley srew anything up? like tune or mess up HP numbers
