CANT get y-pipe on!
Old Jul 2, 2005 | 12:35 PM
bolton98TA's Avatar
Exclamation CANT get y-pipe on!
this TSP y-pipe is being a b!tch to get on!!! what is the best way of doing this? what can i use to make the pieces slide togeather easier?
Old Jul 2, 2005 | 12:46 PM
Lithium's Avatar
SSU's Drunk Typing Whore
I just put some car wash soap in the pipes and that really helped slide them into each other. Also might want to unbolt and move the catback back a little bit, I heard that helps. Other than that it just takes some wrestleing to get them on right. It will eventually go on its just takes some time. Good luck to you.
Old Jul 2, 2005 | 12:58 PM
FBDYLVR's Avatar
We used WD-40 to get hitmeoff's x-pipe on.
Old Jul 2, 2005 | 02:04 PM
bolton98TA's Avatar
i almost have it, on the drivers side the pipe is about 1/2" too low and it hits the underpanel..... this part is probobly harder than the header install!
Old Jul 2, 2005 | 02:05 PM
Lithium's Avatar
Almost. Its definitely a pain in the *** though. Its just takes some tweaking but you will get it.
Old Jul 2, 2005 | 02:42 PM
NO CATZZ's Avatar
Loosen the headers so that you can move the collectors back and forth a little. Since most y-pipes actually curve in and the collectors point away from each other it makes it a real bitch to get them on. Last few times I have done it I always waited and torqued to headers down after I had the y-pipe loosely slipped into place.
Hope this helps.
Old Jul 2, 2005 | 04:05 PM
bolton98TA's Avatar
got it! but the y-pipe is hitting the flore board on the drivers side. its got about 1/2" chearence if that. what can i do?something just dont seem rite about it. can someone send me a pic of their y-pipe on the drivers side (tsp)?
Old Jul 2, 2005 | 05:00 PM
kpowr82's Avatar
Infamous 'y-pipe is too close to the bottom of the car and bangs like a mother f'er' situation. There are plenty of ghetto fixes for the problem, but the only real solution is to get a poly trans mount and/or poly engine mounts. Good luck.
Old Jul 3, 2005 | 03:46 PM
BLUE01's Avatar
go to thunder racing's web site and they have a hanger for $40. It will keep the Y-pipe from banging on the floorboard. I am about to get one myself.
Old Jul 3, 2005 | 03:52 PM
davered00ss's Avatar
Moderator
We had the same problem with my Kooks. Took 3 of us pulling on the y-pipe to get it on. Loosen the headers so they move slightly to get the y-pipe on or use a pry bar and some friends.
Old Jul 3, 2005 | 04:29 PM
Full-Force's Avatar
The driver side of the TSP y pipe is adjustable. Once you get it on you should be able to grab the adjustable piece and twist it back and forth which will move the pipe up and down a little. This will probably get it off the floor but may still bang under acceleration and it will reduce ground clearance.
Old Jul 3, 2005 | 06:50 PM
bolton98TA's Avatar
the only time it bangs is when i accelerate hard or when im stoped on an incline
Old Jul 3, 2005 | 09:56 PM
kpowr82's Avatar
I must be a jackass or something, but for the life of me I couldn't get that mufflex hanger to work with my Kooks ORY. It just didn't line up with the bolt you're supposed to mount it to. I'm pretty upset that i have a useless $40 exhaust hanger sitting in my tool bag.
Old Jul 4, 2005 | 09:42 AM
bolton98TA's Avatar
ima just have the exhaust shop fab me up a hanger. then again i might not need it, it si higging there i have one of thoes damn U-clamps so maybe once i get it welded togeather it will go away. how hard is it to get cats on the TSP ory. i hope my muffler shop can do it
