02 sensors again? 2nd set in 2 months
what could this be? and what do I do about it?
pat
pat
I mean I am all for great customer service, I stive for that at my shop as well, BUT with OBD being out for almost 10 YEARS now AND knowing that the AZ's in my area have been burned countless times from just scanning codes and using the "shotgun"approach at just replacing parts depending on what codes show up(So many times certain codes will be set from parts "upsteam" from the componet that the code identifies) I cant believe they still diagnosis from the parking lot
what's causing these codes? could it be if I'm running rich? or the spray?
there's no loss in performance when the SES light comes on, it's just annoying
pat
I'm going to replace those inline cats with regular cats and ORY and then replace the o2 to see if that works. Who knows...
Called TSP, they told me to reprogram the computer chip.
It seems like the 02 are to far from the headers causing it to throw a code.
Everytime I get the same code, (PO135 SENSOR 1 BANK1 HEATER MALFUNTION)
I was told to knock out the heater part in the 02 sensor,by reprograming the PCM.
If anybody has any better advice than this please let me know.
I had the codes P0135, P1133, 0155 intermittently for a few months. I figured it wasn't actually both O2's bad at the same time. I checked the MAF and it was dirty. I cleaned it up, ditched the K&N and my problem hasn't come back since.
1. Rear corvette specific O2 sensors are supposed to help; I'm still having success with the BOSCH ones now; I too have been through countless O2 sets since 2001.
2. I bought a small $10 propane torch from Lowes; periodically I remove the O2 and put it in the vise. Then hit the sensor for about 30 seconds per 4 sides with the propane to clean any garbage off. This helped me save some O2 sensors
3. My FLP's never had an issue with O2's, just the newer Stainless Works. My thoughts are O2 location in the header
4. I concur with calongo_SS; a dirty MAF will give strange results.
FWIW
well I'm gonna look at the maf sensor and see if it's dirty,
how do I check for exhaust leaks, it doen'st sound like I have one,
how about putting fire boots on the o2 sensors, will that protect them from the heat,
many questions, very frustrated,
pat
