Where and how does the Mufflex LS1 Y-Pipe "Bump Stop" Hanger Connnect?
Hi! Just like the title says: "Where and how does the Mufflex LS1 Y-Pipe "Bump Stop" Hanger Connnect?" I'm using the SLP y-pipe with stock manifolds. At low speeds, the y-pipe loves to bang the driver's side floor under hard acceleration. I see that Thunder Racing has a 2.5" Mufflex "Bump Stop." Where would you locate the clamp on the y-pipe and do you have to drill a hole in the floor, or does it use an existing bolt from the car? Thank you in advance for your help!
It mounts on the driver's side...it uses one of the heat shield bolts...here is a pic of mine installed...note: I had to adjust the placement of mine a little to work with the Kooks ORY, but no banging.
https://ls1tech.com/forums/attachmen...chmentid=33129
Sorry... I know... couldnt resist
Originally Posted by kpowr82
I don't mean to hijack your thread bud, but Lawman, what do you mean by adjusting the placement with the Kook's ORY? For the life of me, I can't this thing to work with my Kooks.
Originally Posted by OldeSkool
Simple. The poly engine mounts replace the rubber ones.
I'm on my way to order from Thunder Racing!
Originally Posted by 2000BlkCamaroSS
True. But not everybody has the opportunity to take their whole engine out when doing a simple mod as headers. Thats overkill.
I only ever had to use my engine hoist once to pull an engine out, and that was just because I was putting a different motor in its place I digress...
