Effects of running without thermostat?
Like whether or not you're in closed loop, and if not the
mixture is pushed all around by it.
If you want to tune it tight you have to give it a tight
environment.
At the 0.5 to 1ish kg/s that engine coolant is flowing through an LS1, there is plenty of time for coolant to pick up engine heat. The reason the engine is running cooler, more coolant is flowing, ie no restriction. More coolant through engine, more coolant through radiator, more heat exchanged.
this won't necessarily cause overheating, it just reduces the cooling ability.
