Granatelli Plug wires over 15 rwhp gain??
Originally Posted by JonB
I don't think it was 15hp i believe it was 8hp and 7ft-lbs. The 15 i believe was with another mod(I think it was an intake) plus the wires. These wires supposidly have a solid core and only have like .02 ohms resistance where the stockers had 8.0omhs resistance. I can't find my chp mag but I believe that is the correct info or at least closer.
I just checked it again, those bastards had the nerve to say 15HP from WIRES ALONE, no other mods.
Wow Granatelli can really get you up to up around 400HP without barely getting your hands dirty!
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Their claims:
- Mass Air Flow Sensor 22HP
- Spark Plug Wires 15HP
- Cold Air Lid 17HP
- Diablo Predator 20HP
74 HP!!!
Why are we all wasting our time with headers, heads/cams, etc?
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
Their claims:
- Cold Air Lid 17HP
74 HP!!!
Why are we all wasting our time with headers, heads/cams, etc?![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
Their claims:
- Cold Air Lid 17HP
74 HP!!!
I just read this CHP article last night and it was 15 hp and 17 ft lbs from the wires. This was also on a 5.3 L truck engine at the wheels. So lets say what 30% loss at the wheels? So the wires were worth 20 hp at the crank? Seems very far fetched unless something was really wrong with the other wires. They do attribute this to the fact that the AC Delco wires have 950 ohm resistance over the 8 inches. The Granatelli's are claimed to have 0 ohm resistance. Any reduction in resistance in the wires will help get better hotter faster spark. Which helps everything overall, but I could only see how maybe 1-2 hp tops as the only mod. With all those other mods, sure, it could maybe give you 5 hp in a perfect world. But I'd have to see it on a dyno with my own eyes. I've been thinking about doing a tune up, maybe I'll spring for these wires and run to the dyno shop and baseline it myself and then change em and see. I don't doubt Granatelli makes a good product, but looking at those 4 mods, yeah, that's over $1000 in Granatelli's pocket per buyer.
Originally Posted by oange ss
MSD plug wires are worth 300+ horses on my car.....my engine with 0 plug wires = 0 horsepower....my engine with MSD plug wires = 382 horsepower.................see they do work...............
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by guinness2
0 resistance is not always a good thing,ever heard of EMI and the havoc it can wreak on electronics.I personally like the Taylor 409's for less than $50 and the Taylor ThunderVolts at about $70 or the MSD's all of which are excellent quality and they look cool too. save the extra $100 and buy a lid cause those wires are like $160 from Summitt
Their claims:
- Cold Air Lid 17HP
74 HP!!!
Their claims:
- Cold Air Lid 17HP
74 HP!!!
Actually $190 from summit, IDK where they got $160 in that article. What's "EMI"?
#32
1 Post
The premise of the article: "Adding 55 Horses with Granatelli Motor Sports Performance Parts"
Part 1: Plug wires. The paragraph --
"Wired for Power
Baseline + Test 1
15.3 hp improvement at 5,250 rpm
17.3 lb-ft of torque improvement at 4,250
These Granatelli plug wires gain an advantage over stock because they are manufactured with a solid stainless inner connector cable wrapped with special fiberglass that emits no noticeable radio interference.
Because the Gen III ignition incorporates a coil-near-plug system, each wire measures about 8 inches from the coil to the spark plug. We wanted to learn why simply replacing the plug wires would yield this kind of power improvement and took an ohm reading on both sets of wires. All the AC Delco wires measured more than 950 ohms of resistance; the Granatelli wires measured less than 1 ohm (.50 actual reading) of resistance. Remember, too, that the Gen III wires are only 8 inches long. If they were as long as a typical SBC the original AC Delco wires would have resistance considerably higher than 950 ohms due to the longer current path."
Part 2: MAF Sensor and Wires
Plus 26.80 hp at 5,250
Plus 38.90 lb-ft at 4,250
Part 3: Cold Air Kit
Plus 55.05 hp at 5,250
Plus 45.10 lb-ft at 4,850
Parts Cost @ Summit Racing.Com
Wires - $160.99
MAF - $329.95
Cold Air Kit - $209.95
Is it Snake Oil orthe truth? Or, does it show how GM has given us a good start but not the whole enchilada with a mass-production product??
We report, you decide.
"Wired for Power
Baseline + Test 1
Wires - $160.99
MAF - $329.95
#33
Electro-Magnetic Interference, causes nasty ticking in your radio, lines running thru your tv, data errors in sensors and other crap like that.
#35
#37
I can honestly say the ONLY reason I bought my MSD super conductors was for apperance, since I went black with a little red for my under-hood setup. I didn't expect to gain any power at all through them, and I doubt that I did
#38
![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
After the test they were believers
I noticed that back in that Lid comparison test they did they were very slanted towards Granatelli, CHP is definitely "in bed" with....
What is a realistic gain (if any) from upgrading your wires/plugs on a bolt on car? Is it worth it? What about ignition ie. MSD - is that for higher HP cars?
Here is a video test on a brand new ZO6 before and after –
http://www.gmsvideos.com/video/1345
I don't think it was 15hp I believe it was 8hp and 7ft-lbs. The 15 I believe was with another mod(I think it was an intake) plus the wires. These wires supposedly have a solid core and only have like .02 ohms resistance where the stockers had 8.0omhs resistance. I can't find my chp mag but I believe that is the correct info or at least closer.
Their claims:
- Cold Air Lid 17HP
74 HP!!!
Their claims:
- Cold Air Lid 17HP
74 HP!!!
If anyone wants to prove me wrong – call GMS direct and we will sell them to you for $105 a set
