Katech Adjustable Tensioner Install and Torque Settings
I have been asked many times about all the specs for installing a Katech Adjustable Tensioner, and I could never find the instructions. I found them, so here they are. I just want to make sure this is in the LS1Tech archive (for as long as this forum is around).
Katech Inc A2299 F-CAR Assembly Instructions
Tensioner is not assembled for installation - Customer must check all final torque specs upon installation onto engine.
1. Fasten 2426 to 2380 using M2437 shoulder bolt as shown. USE LOC-TITE ON SHOULDER BOLT! (No actual picture is provided in the instructions.)
2. Torque M2437 shoulder bolt to 25 ft-lbs.
3. Insert 7/16-20 bolt and washer into 2426 through slot in 2380.
4. Install pulley (not supplied, stock replacement is fine, easily found at Autozone, etc) onto 2426, torque to 40 ft-lbs.
5. Upon final installation on engine torque install bolts to 45 ft-lbs.
6. With tensioner loose, place belt on front drive.
7. Place 3/8" drive torque wrench into square on 2426.
8. Tension belt to 25 ft-lbs (set wrench to 25 ft-lbs, pull until it clicks) with torque wrench.
9. Tighten 7/16 bolt until tensioner does not move.
10. Torque 7/16 bolt to 40 ft-lbs at final belt tension setting.
11. Periodically check belt tension and 7/16 bolt torque. (between every race and practice session)
Special parts notice:
These parts have been specifically designed as a performance part and is intended for Off-Highway application only (yeah right!). Since the installation of these parts may either impair your vehicle's emission control performance or be uncertified under current Motor Vehicle Safety Standards, it should not be installed in a vehicle used on an street or highway (Ooopsie!). Additionally, any such application could adversely affect the warranty coverage on such an on-street or highway vehicle.
B.O.M.
1. 1, ARP-200-8511 Flat hardened washer
2. 1, 7/16-14 x 1.25" Bolt
3. 1, M2437, Modified MSC-04554739 Shoulder bolt
4. 1, 2380 Baseplate
5. 1, 2426 Pivot arm
B.O.M.
