pulley install help
Old Jul 27, 2005 | 09:36 AM
The Sad's Avatar
We had to use a block of wood and hammer to get mine on after the cam swap.
Old Jul 27, 2005 | 05:04 PM
studballs's Avatar
Is the bolt that TSP supplies with the crank pulley longer or standard size?
Old Jul 27, 2005 | 07:33 PM
blkZ28spt's Avatar
As far as I know nobody supplies a longer bolt. Reason being the longer bolt is ONLY used for seating the pulley, it is NOT actually installed. You do not even need the longer bolt. I didn't have one when I did my swap.
Old Jul 27, 2005 | 09:55 PM
Jpr5690's Avatar
o **** i lock tighted my bolt in place ... and the tsp bolt is stock size
Old Jul 27, 2005 | 11:23 PM
Redneck Z's Avatar
QUOTE: You do not even need the longer bolt. I didn't have one when I did my swap.
You don't NEED a longer bolt, but you'd be doing yourself a dis-service not to. your's worked out fine because you heated the pulley. If you don't heat the pulley so you can get enough thread engagement, you will probably strip your threads out. Maybe the stock one will allow enough thread engagement, or maybe it won't. Russian rullet. Many have stripped their threads using the stock size bolt. This is why the instructions recommend using a longer bolt. You MIGHT be able to get away with a stock size bolt, but why risk it. Why risk a major headache when it's completely unecessary? It's easy to find the measurements for the longer bolt, it's all over this site. The only time I'd consider not using a longer bolt, it if heating the pulley allowed it to seat a good deal.
