the cons would have to be changing the gaskets now and then, the stockers can go forever without changing but headers blow out sooner, unless of course you go with quality ones. On my last car I went two years before the supplied paper gaskets needed changing. So its not real bad, but still worse than the stock setup. Clearance underneath can be a problem with cats, but with an off road pipe you shouldn't have any real problems, at most you might have to slow down slightly at speed bumps. With my longtubes I noticed slightly less torque at 1500 rpm, but after that it the same or better than stock. The difference in performance is worth any problems you might encounter. They really pull from mid range to high rpm, actually its quit incredible the difference they can make, it feels like the car can just keep on going past redline and pull to no end. Another con might be the twisting of the car. I noticed right off the bat that the front end lifts up harder, faster and higher than what it did before the headers. I assume this would translate into more twisting of the body, so installing SFC's would be a worthwhile addition to keep out any new squeeks that may pop up. Having to delete codes is another problem, unless you don't care to look at the SES light, I have the OYR pipe and no sims so I get a light, although I don't notice it anymore, so its not a problem. I'm sure tuning would help get the most power and gas mileage, but I haven't noticed any dramatic differences in MPG, its about the same as it was before. I haven't noticed any extra heat or rattling from the inside of any header installs, sometimes it sounds a little smoother since the restriction is removed from the bottle-necked stockers, and the sound didn't increase just sounds more deep, although its slightly louder at full throttle, otherwise it sounds stock. An aftermarket catback would make things louder with the headers, I have the stock one coupled with a cutout. Some people get banging of the Y pipe , I did as well, but I just put one thick washer on each bolt of the stock cross brace, and that cured it right up, and mine banged and rattled something aweful. I had concidered not geting headers because of the problems that can happen, but for the price and performance you gain, they're well worth purchasing.
