Straight duals
I was thinking of doing a 3 inch with 2 sets of bullets, under the axles and all the way back.
I know the X pipe quiets down the car alot and I'm looking for a sleeper sound, but I'm looking for more top-end/end of track power.
Basically something really quiet but free flowing
I figure the 150 shot would help with the torque loss
Thanks
Andrew
. The **** is hella loud and deep. I have no idea if it will help you on top end, but there will be a small weight reduction. I would imagine the added scavenging/power will out weigh the added weight of an X set up.
. The **** is hella loud and deep. I have no idea if it will help you on top end, but there will be a small weight reduction. I would imagine the added scavenging/power will out weigh the added weight of an X set up.Thanks, my car is to loud now
Do you have any track times?
If you do a new system, try to keep the pipes as straight as possible and put the muffler as far back as possible. Do the "H" or "X" as close as possible to the headers.
What kind of bullet mufflers do you have now? Some bullets neck down on the inside and rob a bunch of power.
Balance pipe sizing seems not to be overly critical. The only really influential dimension is the pipe diameter. This needs to have an area at least equal to that of a 2.25-inch diameter pipe (4 square inches) with 2.5 to 2.75 inches being preferable. Though limited to tests on engines up to a little fewer than 600 hp, there seems to be no measurable benefits to using a crossover pipe bigger than 2.75 inches in diameter. As for the crossover length, dyno results indicate that 18 inches responds in virtually the same manner as 72 inches long.
- David Vizard
there are reasons they use X pipes instead of straight duals
