Poly mounts installed...GOOD
https://ls1tech.com/forums/manual-transmission/364694-poly-transmission-mount-tips-impressions.html
Do you guys say you need to pull the alternator to get the long bolt out or is it to get the mount out? I was looking at it from under the car and the mount itself looks esay to slide out, but that bolt may not move all the way out without hitting the alternator. Maybe the alternator could be swung out of the way just a little? I plan on doing the drivers side then maybe the other if need be. Any tips would be appreciated.
AZ will probably only have the black color though, so if you want red, you may have to order it.
https://ls1tech.com/forums/showthread.php?t=364694
