does this sound like a Bad maf?
Hptuners picked up a 'low voltage to maf' code and a "throttle position sensor code". I replaced the throttle position sensor and the problem is still here.
If the VE and MAF tables are far enough off from eachother the result will be a crappy running engine, TPS and MAF codes. Nothing to do with sensors or wiring... Just a thought.
Bad30th
