Aluminum Intakes pros and cons
I am working on a friends car and we are discussing the use of the cast aluminum intakes with the 90* elbos that everyone is using. I have seen them on most radical FI cas and a few other applications. I was wanting to know how they compare to the fast 90/90 setups and it also would be street driven and a 427. So just wanted to get some opinions and experiences you may have had etc...
Originally Posted by KrazyDan
ive read that they can cause a heat problem????
https://ls1tech.com/forums/generation-iii-internal-engine/294024-intake-manifold-flow-test.html
