TB Bypass - anyone seen gains?
Nate
Didn't you know that people who make large salaries and work for well known companies know EVERYTHING. They don't put anything on car that doesn't improve upon it, like some dopey F-body owner who isn't an engineeer by trade might. Nope, everything they've designed is absolutly critical to the proper operation of your automobile.
In fact, if I were you I wouldn't even open the hood of your car. There is a BIG, SCARY engine under there. It is very complex and you won't understand how it works. You need to leave it to well paid professionals at your local Chevy dealer. Only they can begin to understand the whole "cold air, hot coolant" thing.
Will it register a gain on a dyno? YES! But, actually determining defference before and after would be difficult. The slightest change in outside air temp, pressure, humidity, engine temp, and general engine inconsistancy would be more than enough throw off any gains of the TB bypass mod. If all variables were kept constant, which is nearly impossible to do, in my opinion there would be a slight dyno gain. Maybe 0.5-1rwhp. Will there be a gain you can feel? No.
I'm not denying it wasn't put there for ultimate performance. Hell, C.A.G.S wasn't put there for performance. It was put there so that they wouldn't have to pay the gas-guzzler tax on their cars. Pretty clever if you ask me.
This WAS done for a reason. I promise. Just like the baffles people remove doing the !FRA mod.
I highly doubt anyone will ever have a problem doing this mod, but people just need to realize the potential risks involved when it comes to modifying ANY car.
This is why they did it. This mod has been done for I believe 12 years now, with NO negative side effects and is a proven mod. There are NO risks. As the previous posters have explained, this mod has no negative effects even in -0 degree conditions. It was done to cover GM's butt only.
Their reason for installing it :
Automakers test their cars above the arctic circle, and in the heat of South Africa because people might actually try to drive in those temperatures.
My reason for uninstalling it:
I do not drive my car if it's less than 50 degrees out, because I don't have to. So, the tb bypass is patently unnecessary for my vehicles operating window.
