TB Bypass - anyone seen gains?
I found an even cheaper way to do it, by the way. Some of you might have done this, but instead of buying couplers or kits and such, i just bought a 2' hose of the correct size and connected it directly from the radiator to the head coolant lines, bypassing the TB and the factory hoses. That stuff is like $.50 a foot so i paid about a dollar for the mod.
And yes, it does have a function. It heats up the air for starting in really cold climates. If heating the TB was good for performance reasons, you'd see it on every race car. In fact, you see the opposite.
GM, like all manufacturers, has to worry about things other than performance.
I know what its function is for and I know it hurts performance slightly by heating the throttle body which in theory is heating up the incoming air passing thru it. Thats why I do the mod at the track. But it does make my car surge when done and it also does the same thing on my mustang. Don't know why it does this but it does it. When I plug it back up the surging stops. It probably is something else causing this cause my brother has same car and has no problem. Its just funny that it is happening to both of my cars when it gets really cold.
Because these cars must be designed to be driven year round in all 50 states, this (coolant through the tb) is needed from the factory. If your car is never started below 32 degrees F, you don't need it.
I think I remember in cooler weather, there being less of a problem of the TB heating up. In that case maybe the IAT has an effect on cooling down the TB.
Bottom line is though that it makes removing the TB SO SO SO SO SO much easier, as you don't have to worry about coolant spilling out.
There've also been dyno proven results. They show an increase not only when the engine is cool, but also when heat soaked. About 5HP improvement. Not something you'll feel necesarily, but it is there.
I've run it on both my Camaro's LT1 and LS1. At temperatures in the single digits there's been no negative impact.
I performed this mod on my 94 LT1, 99 LS1, my wife's 99 LS1 and my 02 LS1. All this mod. does is prevent the TB from reaching coolant temp. allowing cooler more dense air to reach the intake manifold. It is a proven mod. that yields up to 5 RWHP years ago.
The fact it allows for quicker TB removal is an added benefit
