Overheating
Old Aug 24, 2005 | 04:54 PM
Evo98z's Avatar
Question Overheating
Ok my car overheats when i am doing city driving with the A/C on. The gauge will go to 210 and keep climbing so i have to shut my car off before it gets to hot. I have pressure tested the system and it holds at 18psi, it just has a small leak at the radiator hose were it mates to the water pump (about 1 drop every 6 seconds). So i have to fix this small leak, with a new clamp or something. I also tested the cap and it does not hold any type of pressure whatsoever. The cap that came on my car is not stock, so i am going to get another cap. The other day I let my car idle for a while with the a/c on to check it. My temp went to 210, but fluid was boiling some, and i had just filled it earlier that day with a 50/50 dex-cool mix when it puked some fluid earlier.
My question is would these two things be causing my overheating issue by letting air into the system? If not what might be the cause?
By the way the car is a 98 so i know the temp gauge is telling me whats going on
Thanks
Old Aug 24, 2005 | 06:40 PM
jlrz28's Avatar
10 Second Fun Car
I once had an over heating problem. I got under there couldnt really see anything and out of boredom spun both the fans with my finger and one of them fell off. Come to find out the lefthanded nut fell off.
Old Aug 24, 2005 | 06:51 PM
Y2KblkTA's Avatar
hey man if you got boiling you could have an airlocked coolant system. also take it somewhere or go to AZ and get a combustion leak tester. it should come with some blue fluid. let the car heat up and then suck air from the coolant reservoir where the pressure is and see if it turns green. if it does then you have a blown headgasket, if it doesnt your in the clear and you prolly have it airlocked.
Old Aug 24, 2005 | 07:14 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Originally Posted by Evo98z
I have pressure tested the system and it holds at 18psi I also tested the cap and it does not hold any type of pressure whatsoever.
Thanks
Okay, so you're saying the radiator/engine block will hold 18 psi, but the cap will NOT hold any pressure?
Why don't you get a new cap????
Old Aug 24, 2005 | 10:52 PM
Evo98z's Avatar
I already mentioned I would get a new cap, I am wondering if the small leak and the cap could cause my problem
Old Aug 24, 2005 | 11:00 PM
Carter Hays's Avatar
I already mentioned I would get a new cap, I am wondering if this would be the source of my problem
Yes, and fix the leaks, check that the fans come on when the a/c is on.
Btw, if you can, take a pressure tester when you get your new cap you'll be suprised how some aftermarket ones won't hold
Old Aug 25, 2005 | 12:49 AM
Evo98z's Avatar
I got a cap from autozone and i pressure tested it and it held, but it looked so cheap that i might just get a stock one from the dealer.
Old Aug 25, 2005 | 01:21 AM
WS6freak's Avatar
Check if your 2nd fan is turning on. It should when you turn the a/c on.
Old Aug 25, 2005 | 09:16 AM
408Maro's Avatar
my temp always stays at 210,any reason?
Old Aug 25, 2005 | 10:14 AM
WS6freak's Avatar
Do you *really* have a 160 stat? Did you reprogram you PCM?
Old Aug 25, 2005 | 03:13 PM
Strokinit383's Avatar
Have you changed your fluid lately?
