Pacesetter ypipe merge.
Old Aug 29, 2005 | 04:08 PM
spy2520's Avatar
Default Pacesetter ypipe merge.
Whats the easiest way to clean out all that excess metal to get this thing to flow decent? I'm sure most of you know what i'm talking about but i'll post a pic anyway.
Old Aug 29, 2005 | 04:16 PM
redline2k's Avatar
Replace the merge with a flowmaster collector. My car gained 3 tenths and 3 mph only changing the collector
Old Aug 29, 2005 | 04:17 PM
spy2520's Avatar
See how one side is partially blocked, definitely bad flow.
I dont think i have the tools to do it.
What do i need or where should i go?
Attached Thumbnails Pacesetter ypipe merge.-dscf0557.jpg   Pacesetter ypipe merge.-dscf0558.jpg   Pacesetter ypipe merge.-dscf0560.jpg
Old Aug 29, 2005 | 07:19 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
That is just flat messed up. Mine doesn't look like that at all.
Only thing I can think of is cut the pipe with a sawzall or bandsaw, whack off the excess with a die grinder or sawzall and re-weld the pipe.
Old Aug 29, 2005 | 08:53 PM
spy2520's Avatar
I could've just got a y-pipe made if that was what i was after. I dont want to spend anymore money on a y-pipe i alreadt bought. Good gain, though.
Old Aug 29, 2005 | 08:54 PM
johnpate01's Avatar
Scratch a few heavy marks on the pipes to start with to help align it when you go to reweld it after you cut it apart. I cut it open with a sawzall, used a plasma cutter, and a dremel to detail it. Ten minutes later, it was smoother than you could believe. Then have it welded back up. Good to go.
Old Aug 29, 2005 | 08:55 PM
spy2520's Avatar
Well i do have access to someone who can weld and is going to be welding my cutout back in same day headers go on. Maybe i'll try that. My friend got a tool that might work, a little rotary thing with grinding wheels, may as well give it a try even though it may not be worth it.
Old Aug 29, 2005 | 09:18 PM
BrianC98Z28's Avatar
they dont make a 3in inlet and outlet flowmaster merge. my y pipe is 3in. which merge should i use? 3in inlet 3.5out but my catback is 3in too. Which one should I get?
Old Aug 29, 2005 | 09:19 PM
they dont make a 3in inlet and 3inoutlet flowmaster merge. my y pipe is 3in. which merge should i use? 3in inlet 3.5out but my catback is 3in too. Which one should I get?
Old Aug 29, 2005 | 09:42 PM
Full-Force's Avatar
I used a die grinder with with a grinding stone to grind all of that away. This is the one bad thing about the Pace y pipe
Old Aug 29, 2005 | 10:06 PM
spy2520's Avatar
where exactly can you get a flowmaster merge collector?
Old Aug 29, 2005 | 10:30 PM
Redneck Z's Avatar
Summit Racing.
Old Aug 29, 2005 | 11:01 PM
i didnt see it on summit. I think its on thunders site though
Old Aug 30, 2005 | 06:42 AM
spy2520's Avatar
I think i may already have a flowmaster merge on this y-pipe the guy i bought the car from put on. I'll post pics later for verification.
Old Aug 30, 2005 | 10:47 AM
Redneck Z's Avatar
QUOTE:i didnt see it on summit. I think its on thunders site though
I just bought one from summit. They have good prices and it took 1 day to get to my house.
Old Aug 30, 2005 | 04:48 PM
redline2k's Avatar
I used the dual 3 to 3.5 and a flowmaster cone reducer to get it back to 3"
Old Aug 30, 2005 | 06:56 PM
spy2520's Avatar
This is what is on my car right now. Should i use this merge? what the hell is it? There is a part number on it if anyone knows the p/n to the flowmaster and can verify. How would i go about using this for the headers?
Old Aug 30, 2005 | 06:57 PM
Demon_Speeding's Avatar
When I got my Pacesetter ORY I took care of that ugliness with a Dremel and a flex shaft attachment. Sooner or later I'm going to change that ghetto-fied area to a new collector. Probably a Flowmaster.
Old Aug 30, 2005 | 06:58 PM
spy2520's Avatar
What do you think of that merge i posted above, worth anything?
Old Aug 30, 2005 | 07:01 PM
Phoenix 5.7's Avatar
that looks alot like my flowmaster merge that came with my QTP y. get that thing welded in instead of that pacesetter merge. the one thing that flowmaster makes that actually flows
