Installed my Pacesetters and TSP True Duals
Have only drove it home from work sofar. The sound difference is amazing, it was decent sounding but very mild with the hooker catback and manifolds, but you can really tell its breathing good now. I can tell it makes some more power too in my limited WOT blast before I hit city limits. I'll try to have it dyno'd by the end of the week as I may swap camshafts this weekend if I stay in town.
Ground clearance is also very good at the stock ride height, I've installed a few so of coarse mine is going to be decent too. I'll find some time to post pics up too in the next few days.
Forgot the exact lift (.600"+), but I know the one I have here is on a 111lsa. I'll probably see about getting a few to try with a wider LSA to clear with ported heads with bigger valves as the 111lsa gets a little closer PtoV than I like so we don't push it much...ppl expect it to clear when they get heads since its on the "smallish" side of large.The MS3 currently doesn't fit well without flycutting (non-AFR), although does extremely well with matched with heads. Hopefully the numbers work out to where it will fit with our cylinder head packages for a non-flycut alternative and have the same general .050" specs (235/240).
I do have a few other new camshafts in the works, a MS3 derived cam with a little more lift, should be checking PtoV in a few days on that one and installing it shortly afterwards. I currently have 918's or else I'd try to ****** it up for myself.
you guys ever gonna experiment with some of the lsk lobes. i'd love to see maybe a 224 or 225 duration cam with a good set of heads. maybe on a 112+0.
Prob try a few lsk lobes, don't think they would help on stock heads, but on heads that still make flow @ .650"...well on paper should be better with more lift.
00slpSS,
We have the Dynomax bullets on most of the kits, but offer the Moroso Spiral-Flow mufflers, and someday soon should have the "Sweet Thunder" mufflers in stock. I may work with our exhaust manufacturer (if time permits) and try to get a kit to run the exhaust out the rear of the car for those that don't want to have it dumped. I don't think it will be a full 3" though...will have to neck down to 2 1/2" over the axle.
Loving my TSP TDs w/ Spiral Flows. I get compliments everywhere I go. Great ground clearance and work perfectly with my Pacesetters.
From one Joseph to another - PLEASE find a kit and send it to me ASAP!
I bought a used kit, not a new kit. We're still waiting on the kits from the manufacturer. What name is the order placed under?
