Pacesetters and ORY are in!
Old Sep 4, 2005 | 09:35 PM
'Trust''s Avatar
Default Pacesetters and ORY are in!
6 hours later the pacesetters and ory, caught quite a few snags, but hey, i had to go to an exhaust shop to finish some stuff up, my stock y was welded to the i-pipe instead of clamped and the new ory was short, it sounds good w/the cut out open but like a machine gun at 2500-3000ish rpms, is this normal? also my y pipe is banging, how can i fix this? The car pulls alot harder w/the cut out open, but i can hardly tell the difference w/it closed, could rust in the aerochamber cause this? thanks for any input!
Old Sep 4, 2005 | 10:49 PM
Ell Ess Won's Avatar
Mine sounds gawdy at above 2k RPMS as well.....LT's, ORY, and cut-out open. Closed I think you gain a little bottom end.
Old Sep 5, 2005 | 08:29 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
As far as adjusting the Y pipe (I've got the pacesetter ORY) I loosened the band clamps on the collectors and got a pry bar between the drivers' side and the floor and pried it down while I retightened the clamps. I also shimmed out the tunnel brace a little.
Old Sep 11, 2005 | 11:31 PM
'Trust''s Avatar
how much did that help? did you just loosen the driver clamp?
Old Sep 11, 2005 | 11:43 PM
00PewterSS's Avatar
I had to install the Prothane engine mounts to keep mine from hitting the floor, they basically eliminate engine motion. I can't get mine tucked up enough still to install my DS loop though, and it is extremely close to the floor and the torque arm etc. I am planning on getting a UMI torque arm with DS loop... I hope that will fit!
Brian
Old Sep 12, 2005 | 12:23 AM
Full-Force's Avatar
Hey I never thought about the machine gun expression. Yes it snormal. Its just what these cars do. Some exhaust can mask it better than others. Y pipes seem to be worse than duals. Its what I call rasp. Under moderate throttle between 2200-2800 rpms you will get it.
Old Sep 12, 2005 | 12:42 AM
'Trust''s Avatar
Yup, thats the rpm range, well as long as its normal
how about bolting a clamp the the ypipe that pushes against the crossmember so the pipe cant vibrate because its pushed up to the frame, or is that a bad way to stop it from banging?
Old Sep 12, 2005 | 12:46 AM
BrianC98Z28's Avatar
is it the pacesetter y pipe? i HATE MINE, the y pipe bump stop wont fit right either because of the dent pacesetter has. Im considering going to the TSP y pipe and flowmaster merge for better flow and fit and i can use my bump stop and itll fit right
 Michael S. Palmer
Old Sep 12, 2005 | 08:03 AM
gwj's Avatar
gwj
I believe so, but if that doesn't work try loosening the one where the Y pieces together also. Probably give you a little more "wiggle" room. If you're using band clamps tighten the $hit out of them. I did the readjustment after I had my catback in place.
