Motor Mounts
Old Sep 7, 2005 | 09:27 PM
Ed Blown Vert's Avatar
Default Motor Mounts
I am installing my Thunder Racing motor mounts.
Are they suppose to fit without modifications to the metal?
They don't fit in the clamshell. Did anyone have to cut the poly? Or did I get the wrong ones??
Old Sep 7, 2005 | 09:48 PM
jrp's Avatar
jrp
SN95 Director
mine fit the clamshells just fine. which one's did you order?
Old Sep 7, 2005 | 09:54 PM
The ones they sell on their site. Prothane.
Old Sep 7, 2005 | 10:10 PM
jrp's Avatar
jrp
SN95 Director
these are the ones i got. only problems i ran into were drilling the ****** rivets out of the clamshells. once they were apart thought the mounts fit right in just like OEM.
http://ourworld.cs.com/jrp98ls1/Poly+Motor+Mounts.JPG
Old Sep 7, 2005 | 10:14 PM
Those are the ones I have. Getting the rivet outs were a piece of cake once I switched to Cobalt drill bits.
But mine won't just drop in. I guess I will have to grind down the poly.
Old Sep 7, 2005 | 10:32 PM
Mr. Luos's Avatar
Step on them.
They were tight on mine as well. Needed some convincing.
Old Sep 7, 2005 | 10:34 PM
Cool, just making sure I have the right ones.
Old Sep 8, 2005 | 08:57 AM
00PewterSS's Avatar
That is right, mine had the same interference. I used a 2x4 and stepped on it and pounded it in with the board. I was too lazy to go inside and get the soap, that would help.
Brian
Old Sep 8, 2005 | 07:42 PM
INTENESS's Avatar
Yea I justb installed these just put some grease on them so it will help go in and stop them from sqeeking later on.They are great well worth it to do it.
Old Sep 8, 2005 | 10:06 PM
SVC707's Avatar
did u notice if there is a difference between the two inserts i only have one and want to make sure i have the right one for the driver side
Old Sep 8, 2005 | 10:42 PM
Full-Force's Avatar
You guys that are installing these mounts need to grease the mount good first and then put them in as good as you can by hand and then get the bolts that came with the mounts started and use the bolts to pull the insert into the clamshell.
You also need to scrape all of the old mount out of the clamshell. I use a propane torch and burn it out.
Old Sep 8, 2005 | 11:21 PM
They look the same to me.
