ASP Underdrive pulley Question
Thanks
I think you are talking about the old SLP pulley. The new SLP/powerbond pulley does not have this problem. The new one is totally different. The old SLP pulley as well as some of the ASP pulleys have shown a dip in the curve. The new SFI balanced SLP pulley steel and very strong. The ASP is aluminum. The new SLP pulley also has higher belt retention walls. All the downfalls of the older design have been improved. No KR(powercurve dip), no belt slippage issues, etc.
Are you saying that on idle that you can see the pulley shake? Is that why you said warpped like a ****?
If so get it off NOW. It should be smooth as glass when vehicle is on.
I just had the same thing happen and took it right off and put the new design one on and its perfect now.
ASP webs site... Click General Motors under street pulleys
-William
I just had the same thing happen and took it right off and put the new design one on and its perfect now.[/QUOTE]
YEP...it shakes pretty bad...can this possibly cause my stutter at high rpm due to the bad harmonics?
YEP...it shakes pretty bad...can this possibly cause my stutter at high rpm due to the bad harmonics?[/QUOTE]
It could.
Also it will start causing wear to the internal of the motor bearings ect. You need to replace it asap. It should be smooth as glass. I would not drive it tell you can either put the stock one back on or get a new one.
