A4 guys + asp/ quick intsall ???
Old Sep 15, 2005 | 07:35 PM
2mffZ28's Avatar
Default A4 guys + asp/ quick intsall ???
How'd you stop the crank from turning while trying to get the bolt out? Or while torqueing the bolt down?
Thanks ............
Old Sep 15, 2005 | 08:01 PM
Lithium's Avatar
SSU's Drunk Typing Whore
https://ls1tech.com/forums/showthrea...pulley+install
Do a search as well, plenty of good info out there
Old Sep 15, 2005 | 08:02 PM
GM Muscle's Avatar
Drop the starter and stick a punch in a hole in the flywheel. Some guys use a screw driver but, I've had better luck with a punch.
If you want to do it the right way, Kent Moore sells an $80 LS1 flywheel locking tool.
Old Sep 15, 2005 | 10:10 PM
2mffZ28's Avatar
Thanks guys that sounds easy enough.
GM Muscle, Your car is BAD AZZ. that pic is sweet
Old Sep 15, 2005 | 11:15 PM
SS SLP2's Avatar
REmove the small 2 in round plug on bottom of bellhouseing insert a BIg screw driver or pry bar into the teeth of fly wheel ( you will need a freind to help) may need to insert one behind the flap behind the starter also >>>( NO need to remove the starter) OR you may order the special tool from GM which will bolt to block which will hold the fly wheel
get a big peice of pipe to use as cheater on on ratchet or breaker bar ( some say bind bar and bump starter to loose crank bolt ( I WOULD NEVER DO THIS )
Will need a 3 leg puller that will pull from the inside ( never from outside ) of stock pulley (may rent from local past supplier )
when ready to re install I get two new crank bolts from dealer and weld a 5/8 x 4 in bolt to head of one ,
( will need to grind down the washer on stock bolt so that it will fit threw the pulley) screw the welded crank bolt in to crank slide a socket( one that will just fit inside the pulley- to use as a guide to start pulley stright ) over the welded 5/8 bolt ,use this to pull the puller back on this way you are not puting much strain on the threads inside the crank Lubricate and mount the ASP pulley onto the snout. Once it is pressed close to flush ( about 1/8 being flush) then install old bolt and tighten it to 240 ft. lbs. or until it is completely seated on the crank snout. Afterwards, REMOVE THE STOCK BOLT and replace it with the NEW CRANK BOLT. You will tighten the NEW bolt to 37 ft. lbs. and then turn it an >>additonal 120 degrees.<<<
hope this helps Johnny
ps:: I install a new seal any time I remove a pulley($10.00 and 10 minutes now is better than haveing a leak and haveing to remve pulley again
may make a tool to hold flywheel
hope the drawing of tool is understandable
use a 1/8 x 2 flat bar about 12 in long insert into flywheel threw the round hole in botton of bellhouseing ,the notch in side will hold tool in place
PS: THE DRAWING DOES NOT SHOW UP CORRECT ,it should be about 2 in wide all the way down
Old Sep 16, 2005 | 09:04 PM
RGR Pete's Avatar
I'm lazy, I put the pry bar through the old pulley and against one of the bolts on the drivers side head. Turned braker bar and done.
Old Oct 7, 2005 | 03:33 PM
Jpr5690's Avatar
I Positioned A Breaker Bar On The Ground And On The Bulley Bolt And Tapped The Starter ... It Works Great!! Dont Waste Your Time With The Other Bs This Takes All Of 2 Secconds And Your Crank Bolt Can Be Turned With Your Fingers
Old Oct 7, 2005 | 05:46 PM
J E T's Avatar
Thanks ............
Here's a install guide...
Installing an underdrive pulley
Old Oct 7, 2005 | 05:51 PM
gojo's Avatar
If you do this please unplug the coil packs.
Old Oct 20, 2006 | 08:25 AM
V6 Bird's Avatar
thats an excellent way to break the starter off the block!!! Yay for you!!!!
Old Oct 20, 2006 | 08:56 PM
DrkPhx's Avatar
I use the Kentmoore tool specific for that. Remove the starter and bolt the tool in place which positively locks the flexplate from moving. $$$ but it pays for itself the first time you use it.
Old Oct 20, 2006 | 09:04 PM
s346k's Avatar
we positioned the breaker bar on tthe passenger side frame rail and cranked the engine over with the coil packs UNPLUGGED. worked like a charm.
