post pics of pcv mod/ catch cans
Cool Picture of catch can setup. I'll be putting in my AMW soon.
00firebird - Its actually a can that catches any airborne oil in your PCV system before it gets sucked back into your intake. Oil can get caked on your intake, your heads, your pistons and your combustion chambers causing all sorts or problems like ping and knock as well as just generally garbaging up the whole area.
I have checked my vent line many times cause I thought the same thing but have never had oil in that one
not really a catch can but much more effective
no more knock and a very slight bit better mileage.
With that setup on it also pulls harder the faster the engine is going so under wide open throttle there is a few inches of vacuum on those lines. The pcv quits operating at full throttle due to to low a vacuum in the intake. On my mostly stock car that probably doesn't help much but on a boosted engine that would probably be a lot more useful. Either way it was the simplest way to get rid of the oil in the intake and the knock that it was causing.
