If you get a cut-out what's the point of ....
Originally Posted by SiL3NtXWS6
so, are dual cutouts in the Y pipe going to outflow true duals?
Originally Posted by ebear
That's what I want to know, You might as well run open headers though =P
I have dual electric cutouts. It's not nearly as loud as open headers, trust me on that one haha
TTT
I have headers with a off-road Y and am wondering the same thing. I am thinking of keeping my stock catback and putting a cutout in the I pipe, instead of a aftermarket cat back.
I had 3in duals before on my Z, but i want to keep this car quite, then when i want it loud all i have to do is open the cutout
My opinion......a cutout on a non cammed car sounds like just plain redneck ****. Before my cam, I had it capped ALL the time when I wasnt racing. I say spend the money on a catback, its sounds SOO much better. And if you dont mind beind loud, and dont want to spend 750+ dollars, I would reccomend the TSP Rumbler catback. For 275, you cant beat it. And its PLENTY loud.
My Y is 3" from the headers into a 3.5" flowmaster collecter and then into a 3.5" I-Pipe. I have a 3.5" cut-out before the axle. Civilized on the street and power at the track.
I loose out on low rpm velocity which doesn't help my low end torque, but top end power is there becuase the flow is tremendous.
FWIW, most Y-pipes are crap. The design rams two different flows together at 30 - 45* angles into a single flow in the same size pipe, rather than merging the flows at a narrow angle and feeding into a larger pipe. Fix the design and performance improves.
Dual cut-outs on Y-pipes have not worked as well as expected. I'd do a single cut-out and get 90% of the benefit.
