EGR and AIR system removal
Old Sep 24, 2005 | 11:04 PM
Z28LS1camaroguy's Avatar
Default EGR and AIR system removal
ok well im not going to do it yet but just want the basic info on how it is done exactly. so here goes, i unhook the air and egr and put the block off plates in there place, then i get them tuned out so i dont have egr and air anymore. is that all i need to do or am i missing something??? and also with the block off plates you just bolt them where the tubes use to bolt on and thats it right nothing more. the reason for these questions is that i want the pacesetter race style headers but dont know how easy it is to remove this stuff.
Old Sep 25, 2005 | 12:07 AM
98z28chevy's Avatar
Yeah i believe thats pretty much it. I took out the Air EGR and my AC system out of my 98z i put a 04 ls6 z06 engine in my car. I also added Pacesetter LT's Race Style and ORY. I hadnt got the codes tuned out yet but it drives really great no problems with it. I also took out the Air Pump. Engine bay is so much cleaner now.
Old Sep 25, 2005 | 12:56 AM
blue01ta's Avatar
pm'ed ya
Old Sep 25, 2005 | 02:28 PM
01 Red WS6's Avatar
Don't forget to pull the fuse and relay for the air pump
Old Sep 25, 2005 | 05:42 PM
at least i got how to do it now all i need to do is do it lol. also the EGR or AIR can cause your exhaust to pop kinda right, i mean i take off and its mean as hell and with an open cutout you can imagine, but when i let off the throttle completely and then press the throttle again especially in D on the highway i get a pop sound not a backfire pop like a more exhaust coming through pop. anyone else have this???
Old Sep 25, 2005 | 05:51 PM
kbronSS's Avatar
what exactly are the benefits of remving these items? i too wanted off road headers, but had no idea where to start to remove these things. any extra hp?
Old Sep 25, 2005 | 05:53 PM
no i think its mainly to clean up the engine bay and get rid of the noise the AIR and EGR systems make.
Old Sep 25, 2005 | 06:06 PM
SSBLUBYYOU's Avatar
I didn't pull the fuse on mine when I removed AIR and EGR from my car? Will this hurt it or something? I assume the fuse is marked, correct? I can't go look at it now because my car is parked in a garadge a few miles from my house.
Old Sep 25, 2005 | 07:53 PM
spy2520's Avatar
i never pulled the fuse on mine either, i didnt just get the codes deleted i got the EGR and AIR functions turned off as well, on top of that the AIR pump is removed so removing the fuse seems unnecessary.
Old Sep 25, 2005 | 07:54 PM
98z28chevy's Avatar
yeah i still got my EGR fuse still plug in too.
Old Sep 25, 2005 | 08:17 PM
MattIROC's Avatar
I dont think its necessary to pull the fuses once they are removed with ls1edit or whichever programmer used. No problems here.
1 3/8 plug freeze plug is needed for the egr valve, can be found at Auto Zone, or any other parts store. Its $4-5 bucks.
Sounds like you have everything else covered.
Old Sep 25, 2005 | 08:25 PM
spy2520's Avatar
could be less, mine was only $2 and change. The one i got was 1 1/4 to 1 3/8 or something like that, they have a range on them, if 1 3/8 is the second number it'll work, the other one which is 1 3/8 to 1 1/2 mi ght work as well but i'm just saying the one i tried that worked.
Old Sep 25, 2005 | 08:39 PM
MattIROC's Avatar
I think you're right spy. It might have been cheaper, and the 1 1/4 - 1 3/8 sounds correct.
Old Sep 25, 2005 | 08:41 PM
_JB_'s Avatar
The AIR is refering to the smog pump right?
Old Sep 25, 2005 | 09:41 PM
spy2520's Avatar
yeah, the one under the drivers headlight that connects to both manifolds.
Old Sep 25, 2005 | 09:47 PM
01 Red WS6's Avatar
The point of removing the fuse and the relay is to make sure the car doesn't try to cycle through the AIR system... Its not a big deal and if you remove them with LS1 edit or HP tuners then you don't have to worry about a thing
Old Sep 25, 2005 | 09:52 PM
01redws6 you have all those mods and only have 320 horsepower? that seems strange with all the stuff you say you have on the car.
Old Sep 25, 2005 | 10:37 PM
spy2520's Avatar
you know if you cut all the manufacturers stated gains in half thats probably what you end up getting.
Old Sep 25, 2005 | 10:41 PM
true but still he has to be producing more than that with a WS6
Old Sep 25, 2005 | 11:56 PM
Daredevil_TA's Avatar
well just cuz its a ws6 doesnt mean its faster, some ls1's just respond better to mods then others, and to answer the question about the egr and air relating to performance gains, no there is none-if anything it would take some weight off the car which is always good-but egr and air is strictly for emissions, it has nothing to do with the performance of the vehicle.
