Difference between black and ceramic coating?
Old Oct 9, 2005 | 10:32 PM
1fastz's Avatar
Default Difference between black and ceramic coating?
i know this might be a stupid quetion to many, becuase many of you are all experts at knowing this.....but what is the difference and advantages of having a ceramic coated headers over black coated? i heard that the ceramic wont rust and that they flow better? is this true?
Old Oct 10, 2005 | 08:10 AM
Order 66's Avatar
If you are referring to the Jet Hot 2000 which comes in black vs there ceramic chrome, there is a difference. The blak 2000 is a heavy duty version that hold up to 2400 degs if i am correct. Its like tar. Very god in turbo applications. And its not the coating that rusts its the material that does. Coating stainless steel wont rust. Coating mild steel will rust in time.
Old Oct 10, 2005 | 08:13 AM
777's Avatar
777
I'm sure he is talking about just the flat black paint vs the ceramic coating. The ceramic will hold in heat better and it will resist rust much better. The more heat you can hold in the better the power.
