Race Gas and o2 sensors, please help
Old Oct 12, 2005 | 04:22 AM
Solid346's Avatar
Default Race Gas and o2 sensors, please help
i am really tired from the stock o2's which they are dying every run i make due to the use of 116 octane gas. i did a research on the denso sensors but dont know the which one i should go with and where i can buy them..
please help
Old Oct 12, 2005 | 04:26 AM
WOT's Avatar
WOT
I would love some info on this as well. i run into the same problem with 110. 02's get expensive real quick.
Old Oct 12, 2005 | 08:53 AM
Bryan @ Speed Inc.'s Avatar
you guys talking about the fronts???
Old Oct 12, 2005 | 03:50 PM
Solid346's Avatar
yes, the ones that goes into the headers. my A/F ratio is gone nuts
any users
Old Oct 12, 2005 | 06:52 PM
black01_WS6's Avatar
how about stop using race gas. look up torco race fules if you are gonna run higher octane. If you run leaded race gas you will burn the o2's all the time.
Old Oct 13, 2005 | 12:26 AM
Solid346's Avatar
My cr is 13.2:1, so regular gas wont work, and other problem i am oversea's, so C16 is the only brand avilable
Old Oct 13, 2005 | 01:06 AM
smoknta's Avatar
I have heard of O2's that are lead resistant, but I'm not sure where you can get them.
Old Oct 13, 2005 | 09:08 AM
psykoTA's Avatar
I never heard of them, but if there are some, I'd like to know.
Old Oct 13, 2005 | 05:32 PM
WOT's Avatar
WOT
what about when running race gas that is unleaded? I am still going through 02's at an alarming rate.
Old Oct 13, 2005 | 05:43 PM
still going thru o2's with unleaded race gas? probably too rich. might try switiching to the corvette o2's they seem to take more abuse than the f-body o2.
Old Oct 14, 2005 | 10:01 PM
WILWAXU's Avatar
I've heard that the Denso O2's will stand up to leaded fuel.
Old Oct 15, 2005 | 12:06 AM
DanO's Avatar
rule of thumb
O2's dont like lead.
Its just about the fastest way to kill an O2 sensor.
Old Oct 15, 2005 | 01:15 AM
Solid346's Avatar
well i finally got a website that i can get it from OxygenSensors.com, i hope the denso ones that they have is the right part for my application.
Old Oct 15, 2005 | 01:28 AM
Wicked_Hugger99's Avatar
leaded eats em up..been there, done that. Was buying 106 from a local round track that told me it was unleaded but they were just a wee bit wrong Try and get some unleaded unless the Denso's are lead friendly
Old Oct 15, 2005 | 03:23 AM
BrianC98Z28's Avatar
my friend runs 100 UNLEADED with no problems, he doesnt run it at the track ALL the time only when shootouts or something is going on and hes going to be spraying.
Old Oct 15, 2005 | 09:30 AM
NAVY's Avatar
What is the difference between the Walker 250-24087 and the Denso 234-4025 ?
Old Oct 16, 2005 | 01:56 PM
NAVY's Avatar
any help pls
thank you
navy
Old Oct 17, 2005 | 03:23 AM
z-ya's Avatar
Turbo buick boys report that the denso sensors are in fact much more lead tolerent than any other sensor.They regularly run c16 with their 20+ lbs of boost and get from
3 to 10 times more life from a denso sensor.They have better sheilding and a unique
construction to make this happen.They don't cost any more than the delco junk ,
what have you got to lose?Oxygensensor.com and look up your application,don't get
the universals,get them application specific preterminatated.
