Flow Tech LT's = CRAP
Old Oct 26, 2005 | 08:34 AM
TWISTEDTA's Avatar
Default Flow Tech LT's = CRAP
Yea so everybody told me these were crap because the flandges are to thin and people always over torque them and bend them = Leaks...Well i bought them anways, for about $150 with Y pipe (used of course) I told my self i wouldnt bend them or over torque them-& Thats the FIRST THING I DID!
So besides kicking my self in the *** and buying new headers do you guys think theres a way to fix them? I probley could bend them back but how would i know when there streight?
Id probley make them worse. Im going to double up on gaskets and maybe that'll help. Do any of you have any other ideas?
Thanks guys
Joe L
Old Oct 26, 2005 | 08:57 AM
black01_WS6's Avatar
throw them away, and put another notch on the belt for learning the hard way
Old Oct 26, 2005 | 09:23 AM
scottyballs's Avatar
try Jethots I had no problum out of them at all and are good quality for the price..
Old Oct 26, 2005 | 09:26 AM
777's Avatar
777
Old Oct 26, 2005 | 09:32 AM
SUTTERERMAN85's Avatar
well i now know what not to buy thanks
Old Oct 26, 2005 | 10:03 AM
TWISTEDTA's Avatar
Me
Flow Tech
Me
Flow Tech =
Old Oct 26, 2005 | 10:08 AM
MAXIMO's Avatar
You could see if this works. My Y pipe had gotten hung up on on a Rock and tore it up. With this it made the header leak. I took it to a guy I knew and he heated it up and made it straight, No more leaks and he used the same gasket. This might work for you as well. Worth a try.
Old Oct 26, 2005 | 08:18 PM
dame's Avatar
Buy a set of QTP's (w/hvmc) and then KICK yourself several times for not shelling out the money for a QUALITY part the first time!
Old Oct 27, 2005 | 04:45 AM
Thrasher245's Avatar
I had a bent flange on another car and leaked, I forget what its called, but its like a paste you can sick on either side of the gaskit and slap it together (its not gaskit maker)...When you start the car, the heat will cure it and youll have a leak free flange! Worked great for me. I got it at a local car part store. Hope that helps.
Old Oct 27, 2005 | 10:13 AM
TWISTEDTA's Avatar
Question
Thats sounds like a good idea-I dont want it to look tacky though...
What do you guys think of pacestters? They are really cheap too (in price) how are there quality?
Old Oct 27, 2005 | 10:40 AM
Mike2000Z28's Avatar
pacesetters have been great and I have had no problems with mine. Look at the amount of sigs with people that have pacesetters.
Old Oct 27, 2005 | 10:46 AM
Scotty-Z's Avatar
Yup, Pacesetters are the way to go if you're looking to stay cheap, but still have good quality.
Pacesetter price is around Flowtech's, but Pacesetter is FAR ahead in terms of a good product.
I hate to say it, but it's really a shame that more people don't listen to some of the guys on here. They'd save a lot of time and money, because the guys on here often know what they're talking about
Old Oct 27, 2005 | 11:58 AM
Jimmy P's Avatar
Go with Pacesetters. Mine are great. Only complaint is that they have been on teh car for about 2.5 months and 1500 miles, and the coating on the underside doesn't look too great. For the money I payed for them I couldn't care less.
Old Oct 27, 2005 | 04:10 PM
TWISTEDTA's Avatar
sweeeeeeeeeeeeeeeeet!! thanks guys, just orderd them & they come in tommorow. Total was 320$
Old Oct 27, 2005 | 05:33 PM
hope it all works out for ya
Old Oct 29, 2005 | 01:06 AM
d james's Avatar
Sorry to hear about the problem-is it the primary flange your talking about or the flange for the Y pipe? I love my flowtechs-I don't get any leaks or even ticks that alot of guys get with headers. Maybe its luck of the draw, I know I torqued the hell out of both sets of flanges and am without leaks-maybe they make them thicker now, cause mine aren't to old.
Old Oct 29, 2005 | 01:29 AM
Full-Force's Avatar
Its the primary flange that bolts to the engine. Its only 1/4" thick. The problem with using 1/4" on that header is that inside the flange the primary tube weld is in there and its raised which keeps the flange itself from laying flat agains the head. When you go to tighten the bolts down the welds are lying against the head and the flange gets " pulled" toward the head at every spot where there is a bolt.
I put a set of flowtechs on a car and used brand new OEM gaskets which is all I ever use and they still have a slight leak.
The Pacesetter header has a thick 3/8" flange, even thicker than the Hooker. It will not warp.
If you look at the poor flanges, the factory made dent in the tube near the k member, and the fact that they are as much as Pacesetters then it makes no sense to buy them.
Old Oct 29, 2005 | 02:52 AM
Lurch84's Avatar
I have a set on my truck, its just got a normal ole small block! I had problems too, then i tried some of those copper gaskets, tightened them once and that has been it! There tight everytime i check, the gaskets come with there own bolts and lock washers!
Thou my hookers did alot better for power, but these were free so what the hell!
Old Oct 29, 2005 | 01:02 PM
TWISTEDTA's Avatar
[QUOTE=Full-Force]Its the primary flange that bolts to the engine. Its only 1/4" thick. The problem with using 1/4" on that header is that inside the flange the primary tube weld is in there and its raised which keeps the flange itself from laying flat agains the head. When you go to tighten the bolts down the welds are lying against the head and the flange gets " pulled" toward the head at every spot where there is a bolt.
QUOTE]
That right there is exactly what happend to me! My 1st set ogf headers were Edebrock shortys, but were flush agiants the head. I assumed these had to be flush too...Oh i was wrong. Yea some people get luck but its very few. I got my pacesetters in yesterday and they look like great quality. The only thing is that i didnt pay attention that i orderd the non coated Oh well...Hopefully they dont rust to bad and when they do some WD40 can help me out hehe
Old Oct 29, 2005 | 08:16 PM
Full-Force's Avatar
You headers are gonna rust quick. Doesnt mean they are no good, they just wont look so hot. The paint will come off upon cranking it. You might get you a can of that 1200 or 1500 degree ceramic paint at Advance. Strip the paint off of them first or the black paint will lift the ceramic paint with it.
