Difference Between Corvette and Camaro (V6) Intake
This may be a really stupid question, so I appologize.
Application:
CHEVY CORVETTE 5.7L 97-00 W. 2PCS FILTER
Do you think that would work with the V6 Camaro (with slight modification of course.)
~Fred
Application:
~Fred
Only problems will be locating it and actually fitting the tubing to the TB/MAF or where ever. Might be cheeper easier to by the filters seperatly and get some angled silicon tubing to the shape size you need.
Do you think I will see any gain in power with it?
~Fred
im sure you will pick up some power. might also look into some way of blocking off the engine heat if it is close to the engine
Don't think heat will be a big problem. The left would is going to be right in front of the condensor for the AC, which is always cold. :-)
