Y-Pipe Bumping the floor?
Old Nov 9, 2005 | 09:29 PM
Camaro Z's Avatar
Default Y-Pipe Bumping the floor?
I remember sombody asking this a while back, but i had my y-pipe raised a little bit and now it vibrates on the floor board when i get on it hard. what is the best way to fix this.
Old Nov 10, 2005 | 09:56 AM
LiquidSword's Avatar
Loosen up the y-pipe bolts pry it down some and shove some 2X4's in the areas where it's hitting tighten it back up REAL good so it keeps this from. Pry down some more and remove wood.
Thats one way it might fix. Worked on my friends car and I'm gonna do it to mine soon. And we both have the mufflex Y-pipe bracket too.
Old Nov 11, 2005 | 08:55 AM
SUTTERERMAN85's Avatar
get a 5lb sledge
Old Nov 11, 2005 | 09:07 AM
mrbobo's Avatar
Good advice. Some guys have installed poly motor mounts as a cure. I installed my poly mounts when I installed the headers.
Old Nov 11, 2005 | 12:55 PM
Camaro Z's Avatar
I fixed it, all i did was wraped a little peice of hydralic hose around it and clamed it on, worked fine and didnt cost me a thing.
Old Nov 11, 2005 | 12:59 PM
V6 Bird's Avatar
Originally Posted by SUTTERERMAN85
get a 5lb sledge
Id rather clearance a little like that myself then adjust it and scrape the **** out of it on the ground.
Old Nov 11, 2005 | 06:12 PM
99FBODY's Avatar
i got bracket welded in. that took care of my problem never make noise again.
Old Nov 11, 2005 | 06:20 PM
Letsndy's Avatar
thunder racing has a thing for it. i have it and it works very well.
Old Nov 11, 2005 | 06:57 PM
radz282003's Avatar
Ditto.
Old Nov 12, 2005 | 02:08 AM
Xtnct00WS6's Avatar
My Y pipe was actually hitting on my stock torque arm. It eventually made a good enough dent in the pipe that there wasn't usually any vibration/noise. I just installed a BMR Adjustable Torque arm and now I have much more clearance between the Y pipe and Torque Arm. I notice a lot less vibration/bumping now. Having the poly bushing in the clamshell on the tranny prolly helps too. I also had the mufflex hanger and it didn't work that well.
Old Nov 12, 2005 | 07:34 PM
Cheater's Avatar
damn man thats a good idea with the 2x4
Old Nov 12, 2005 | 07:50 PM
DreamState23x's Avatar
Just cut out the floor board, you don't need it anyways..
