O2 Sensor removal?
Old Nov 12, 2005 | 04:54 AM
SmokeShow99SS's Avatar
Question O2 Sensor removal?
What is the best way to remove the O2 sensors to install on LT's or is it just smarter to buy new ones?
Old Nov 12, 2005 | 09:36 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
You should be able to remove them with a wrench, can't recall the size off the top of my head though....
As for getting new ones, I wouldn't worry about replacing the rears as they have no bearing on a/f mixture, but as for the fronts, if you have some decent miles on them then it might not be a bad idea to put in new ones since you're putting in the headers anyway.
Old Nov 12, 2005 | 11:12 AM
Lithium's Avatar
SSU's Drunk Typing Whore
Just find an adjustable wrench and turn.
They will be on there pretty tight, so it may take a little time to get it loose.
Well you remove all four sensors and only use two of them for the fronts. So you will have two sensors left over. If they fronts give you any problems then you can switch them with the rears that were left over. Since they are all intechangable.
If that fails then buy some vette ones.
Old Nov 12, 2005 | 03:52 PM
The car has 70K time for new ones?
Old Nov 12, 2005 | 03:54 PM
Lithium's Avatar
I would wait and see how they do first...if they are setting off codes or whatever then go ahead and get some new bosch's.
Old Nov 12, 2005 | 05:04 PM
Phoenix 5.7's Avatar
i reused my stockers when i put my LTs on my car. when they go out, im goin to put the other set i got from the rear O2s. does anyone know what the vette ones cost?
Old Nov 12, 2005 | 06:13 PM
CRL 01 SS's Avatar
The Corvette o2 sensors, Bosch PN#:13111, cost about $67.00 each at my local Autozone.
SmokeShow99SS, with 70K miles it would be a good idea to go ahead and replace your front o2 sensors with the sensors mentioned above. You won't need o2 extensions because the Corvette o2 sensors come with longer wires. To remove your old o2 sensors you'll need a 7/8" wrench.
Old Nov 12, 2005 | 06:30 PM
BULLET99Z28's Avatar
Default O2 wrench
Actually, for a better fit, the sensor takes a 23mm wrench. they shouldn't be bad, lust did my LT's last weekend, and the sensors weren't that tight. good luck.
Old Nov 12, 2005 | 10:41 PM
So everyone agrees to get the after-cat O2's for a Vette? Does it matter the year or will this one work?
O2 sensor
Old Nov 12, 2005 | 10:47 PM
Lithium's Avatar
just so they are the 13111's go for it.
There is a longer one as well...I ordered this one a week ago myself. I will find the part number for ya.
