need help fast!!! please
Old Nov 12, 2005 | 08:07 PM
circusboy's Avatar
Default need help fast!!! please
i just installed pacesetter lt headers. got it all back to gether and it's not running right. when you first start it, it revs up to 3,000 rpm. then idles down and tries to run at 3oo rpm. then repeats this cycle evry ten seconds or so, if it will stay running
Old Nov 12, 2005 | 09:23 PM
NviouSS's Avatar
make sure all your plug wires are on tight. which gaskets did you use?
Old Nov 12, 2005 | 09:37 PM
Lithium's Avatar
SSU's Drunk Typing Whore
first just go over all of it making sure everything is plugged in. Is it throwing any codes?
Old Nov 12, 2005 | 10:25 PM
circusboy's Avatar
thanks. i went over everything twice. i'm really tired. i'm walking away from it till tomorrow.
Old Nov 13, 2005 | 07:37 AM
T-maxx's Avatar
Try dissconecting the 02 sims.Or you might have dammaged one of the front 02 sensors, those are easy enough to check. Best thing to do is see what codes its throwing. Sry I couldn't help you out more
Old Nov 13, 2005 | 02:46 PM
WhiteRhino's Avatar
Another thing that will cause that is the temp sending unit in the drivers side head.When you were installing the headers you may have broken it or yanked the wire.Its on the drivers head in the front,above the #1 plug hole.Just throwing out more ideas.
Old Nov 13, 2005 | 05:41 PM
circusboy's Avatar
i got it fixed. i purchased 2 new o2 sensors and an obd2 scanner. i was getting a P0108 map high voltage code. i installed the o2's, the tsp y-pipe and hooked the y-pipe into the rest of my exhaust. i fired it up and it was still doing the same thing. my buddy started the car ad i found the vac leak. it was the egr pipe that goes to the intake. it had sucked the rubber gasket partially into the hole. i fixed that and it runs fine now. except for the small header leak on the driver side, lol.
i think the computer was trying do some learning as well. thanks eveyone for all your help.
Old Nov 13, 2005 | 06:07 PM
T-maxx's Avatar
Glad to here that, good job. It's the little stuff that kills you.
Old Nov 13, 2005 | 06:17 PM
2K2WS6TA's Avatar
Thanks for posting what fixed the problem, so many don't, and we never know what the solution was
