Did you keep your AIR?
Is the AIR and EGR a F-Body/pre 2001 Car only Problem? I thought there are street legal Gen III & IV engines with out EGR and AIR System cos of ETC, better cams and PCM. Judging from this answer, there is no AIR "Today"
http://www.performancetrucks.net/for...d.php?t=355404 or am i
?To plug to EGR hole: GM PN 12558346 looks better
Here's what I used: http://www.sjmmanufacturing.com/cam_eng_ls1.html
Technically you need to have it to pass. In TX you only need to pass the OBDII scan and the visual check.
Removing the AIR system will make you fail the visual check. Also many places you can find to pass this up since it's only a visual check. So if you aren't throwing any codes you'd be good to go if you can have them pass up the visual check.
It has a pressure differential sensor of some sort and CAN tell if the pump is actually feeling a little back pressure when the car is running.
Removing the entire pump will definatly set off a code (i can imagine).
