View Poll Results: Did you keep your AIR when you installed headers?
Yes
47
23.15%
No
156
76.85%
Voters: 203. You may not vote on this poll
Did you keep your AIR?
Old Nov 30, 2005 | 11:25 AM
  #81
ShevrolayZ28's Avatar
Originally Posted by Sharpe
Wait. Not sims, you mean sensors, right? You still need O2 sensors and extensions. Sims are for simulating O2swhen you take them out, right?
Yes. Specifically, the sims are for the rear o2 sensors when you take them out. The fronts are still used and need wire extensions because they end up farther back when using LT headers.
You can either use sims for the rear o2's or have the error codes deleted by using LS1 edit or other computer tuning gadgets.
Old Dec 2, 2005 | 05:59 AM
  #82
Fredzep's Avatar
I bought my WS6 without AIR and live in an emmission's area. I simply registered the TA at my Mom's who does not have emmissons.
Fredzep
Old Dec 2, 2005 | 06:09 AM
  #83
JL ws-6's Avatar
Race your car!
My air is gonzo.. and my car went thru emmissions no problem. Literally, once you get it tuned out, you will realize, it does absolutely NOTHING once a car has warmed up. And, if you changed the exhaust, went to longtubes, regardless if the Y has cats or not, they are so much farther back that the air doesn't work right anyway. RIP IT OUT< it is nothign more then 12 lbs of dead weight.
Old Dec 2, 2005 | 09:22 AM
  #84
DarkAzNite's Avatar
I too want to know if there are some photo's or removal instructions. Air and EGR are two seperate systems if I understand correctly, EGR on 1999 has a tube in top of intake manifold and the runs over to some kind of pump right next to the passenger side front of motor, so when removing this, i remove the tube, and the valve thingy, when removing the air, need to remove the pipes from the exhaust manifold, block openings, remove the pump under the headlamp, and the tubing running from pump to each side of motor.
Correct?
Old Dec 13, 2005 | 09:14 PM
  #85
Mike98WS6's Avatar
My A.I.R. is out and staying out. Plus it looks much cleaner under the hood without it.
Old Dec 13, 2005 | 09:19 PM
  #86
Johnny5's Avatar
I only regret getting headers with provisions built in to use the AIR system. It would have been cleaner without the tube and block-off plate on there.
Old Dec 14, 2005 | 02:44 PM
  #87
silver02Z's Avatar
Removed mine! No regrets! Gained 40HP after tune
Old Dec 14, 2005 | 03:56 PM
  #88
Arachnotron's Avatar
I haven't found a clear answer for this, but if you remove the AIR system and retain your cats will it have any negative effect on them?
Old Dec 15, 2005 | 12:00 PM
  #89
Flawless02SS's Avatar
Def no regrets here!! Mine was the first thing on the to-do list when I did my header install. With all the ugly hoses gone engine bay tooks 10x better. The ones that keep AIR, you can probably count them on 1 hand! Ditch it, really no need to keep it.
Old Dec 16, 2005 | 03:29 PM
  #90
hrsspwr's Avatar
I was told it will eventually ruin you cats. The cats need the AIR system to operate properly. I think it also eliminates the gas smell some people report smelling out of their exhaust.
Old Dec 16, 2005 | 03:39 PM
  #91
MeentSS02's Avatar
Kleeborp the Moderator™
From my understanding, the AIR system helps out the catalyst when they are cold (on a cold startup). It doesn't run all the time, as it is not needed when they are warmed up.
I don't see how not having it could kill the cats...it only helps their efficiency when they are cold.
Now, if you send too much heat through them, you'll kill them in a hurry (hence why our PCMs have Cat Over-Temp protection).
Everyone should do like me and just reroute the AIR system back into the manifold. It is just like an electric supercharger, only you got one from the factory!
Old Dec 16, 2005 | 08:06 PM
  #92
JL ws-6's Avatar
Race your car!
Routing the air system into the manafold.. probably not a good idea.
As for the system, it does tuen on and off while driving too, when the car's o2 sensors deem it nessassary for proper cat operation.
Bottom line... if you care about the envoirnment.. then leave it on. But, on that note, if you care about teh envoirnment, why are you driving a V8 car?
Rip it off, along with all the other emmissions **** If your car is bone stock, and you never plan to do anything to it, then leave it on, but if you are like 99% of the people with these cars, and 100% of the people ont his board and have done mods for performance, rip the junk off, it's only another thing in the way when working on the car.
Old Dec 16, 2005 | 08:34 PM
  #93
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Mine's gone too. I didn't pull mine until after about two years of having LTs on my 'bird, so I've got the block-off plates now. Appearance-wise, the block-off plates don't really bother me.....so I guess that's all that matters.
Old Dec 16, 2005 | 08:40 PM
  #94
y2k_ta's Avatar
'Bird Director
Here's a few that I took...
http://www.scottsrides.com/smr00taEGR_AIRinstall.html
Old Dec 17, 2005 | 05:57 PM
  #95
MeentSS02's Avatar
It was a joke man...
Old Dec 18, 2005 | 07:15 AM
  #96
JL ws-6's Avatar
Race your car!
Sometimes I wonder.. I have heard so many goofy *** things that people have tried/done... it's scary sometimes.
Old Dec 18, 2005 | 11:47 AM
  #97
SS1875's Avatar
Originally Posted by ShevrolayZ28
Getting a huge fine or failing inspection would be considered regretful.
This is true if living in a state the requires inspections however if you dont then take it off along with the EGR and have it tuned out of the computer. As stated by other's, it cleans up the engine bay and gives much better access to work on things. Just my opinion.
Old Jan 3, 2006 | 04:01 PM
  #98
rgaynor85's Avatar
now what i wonder is im in NJ and i have the sniffer does the AIR cause it to fail or does it only make a diffrence when cold. visual is not a big deal i have private shop do it and as long as the emissions pass they will pass it. so will it change the emmisions or no?
Old Jan 3, 2006 | 05:46 PM
  #99
slayer6x6's Avatar
The air pump just brings the catalyst up to operating temperature quicker. As long as they test the vehicle when the engine is warm (most do anyway) It will be no different.
Old Jan 3, 2006 | 09:12 PM
  #100
99legnd2rZ's Avatar
so if you remove the air and get codes...can the dealership take care of the codes with tuning. And if not...how much is the software to program the car?
