View Poll Results: Did you keep your AIR when you installed headers?
Yes
47
23.15%
No
156
76.85%
Voters: 203. You may not vote on this poll
Did you keep your AIR?
Old Nov 17, 2005 | 09:49 AM
  #41
Michael02hawk's Avatar
Originally Posted by LiquidSword
I wanted to go with out it, but I was told that it throws a code unless you program it off. Is that true?
I do prefrer the way it looks with out them much better.
Here is how to re-program for the codes:
http://bowlingss.com/Removing%20Air_...%20Ls1Edit.htm
During inpection, most garages (short of the dealership) dont even know to look for an AIR system. In any event, I've kept the pipe, check valve and tubing (for each side), that runs out from the headers, I could easily re-mount that stuff once a year, during the visual portion of the inspection. So no biggie.
Old Nov 17, 2005 | 09:53 AM
  #42
01formula6's Avatar
Like almost everyone else said... just take it off and toss it. Engine bay looks much cleaner, much easier to work on, and saves a little weight.
Old Nov 17, 2005 | 10:40 AM
  #43
DarkAzNite's Avatar
where does everyone get the block off plates for the manifold and intake?
Old Nov 17, 2005 | 11:54 AM
  #44
ShevrolayZ28's Avatar
I might make my own but this place sells them:
http://www.ls1speed.com/catagory.cfm?catagory=Exhaust
Old Nov 17, 2005 | 01:37 PM
  #45
setxws6's Avatar
Have any of you ever weighed the whole system? I would think that the pump has a little weight to it?
Old Nov 17, 2005 | 03:09 PM
  #46
DarkAzNite's Avatar
Is the EGR part of the AIR system? I mean, can i pull the air and the pump and still have the EGR?
Old Nov 17, 2005 | 03:14 PM
  #47
Viper's Avatar
2 different systems. So yes you can.
Old Nov 17, 2005 | 03:24 PM
  #48
MeentSS02's Avatar
Kleeborp the Moderator™
My check valve was squeaking, so I tossed it. I've thought about emissions from time to time, but have never regretted it. FL doesn't have emissions, so as long as I stay in the military, I won't have to worry about it.
Old Nov 17, 2005 | 03:29 PM
  #49
00'WS6Rocket's Avatar
I just took off egr, but I kept the a.i.r. becuase I kept the cat's.
Old Nov 17, 2005 | 04:05 PM
  #50
DarkAzNite's Avatar
I hear so many different things. leave this, get rid of this, my concern is Texas is now Emissions testing, I have stock manifolds and will be a while before can afford headers, it would be nice to clean the engine bay up a bit, Main question, if remove AIR, leave EGR, will I possibly fail emissions (not concerned with a visual check)?
Old Nov 18, 2005 | 12:28 AM
  #51
BriancWS6's Avatar
If either system is removed you will throw a code unless you have it turned off via LS1edit, or HPtuners. Once that is done, your good to go.
I have been without AIR and running an ORY since first of June without having the codes turned off. I just have to stare at the ses light. Oh well, it doesn't hinder performance, so I will have it turned off after the heads/cam and a dyno tune
Old Nov 18, 2005 | 03:27 PM
  #52
black01_WS6's Avatar
got rid of it and haven't looked back. cleans up the engine bay as well.
Old Nov 19, 2005 | 08:25 PM
  #53
I live in texas just get your car done with ls1 edit and it will clear the code from coming on or being detected at the emissions station
Old Nov 19, 2005 | 09:05 PM
  #54
blkZ28spt's Avatar
Didn't keep it or EGR. Absolutely no reason to keep it, no regrets.
Old Nov 21, 2005 | 08:30 AM
  #55
DarkAzNite's Avatar
Right On.
Thanks All
Old Nov 21, 2005 | 12:45 PM
  #56
NBMgreg's Avatar
my question is, im getting pacesetter lt's soon, with a ory... do they sell lt's with egr but NO AIR??? how are you guys keeping the EGR but deleting AIR? just weld over the AIR openings or what?
Old Nov 21, 2005 | 05:15 PM
  #57
natronathon's Avatar
i tore mine out, and cut myself in the process... definetly makes the engine bay cleaner, and damn.... id do anything to make changing plugs easier.... plus, KS has no emissions testing!!! WOOT!!!
Old Nov 22, 2005 | 06:42 PM
  #58
yes I cut the egr tubes off and welded the hole shut
  #59
or you can get racing styly headers I don't think they have egr or air provisions
Old Nov 22, 2005 | 06:53 PM
  #60
pdd's Avatar
pdd
i pulled my AIR out too
