Spark Plug Wires
Old Nov 24, 2005 | 12:11 AM
WS6FirebirdTA00's Avatar
those boots are a waste IMO, might as well get a wire that fits right and save themoney
Old Nov 24, 2005 | 06:50 AM
MonteHawk's Avatar
Default Spark Plug Wires
Thanks guys. I thought about removing the coil pack too.
Back under the hood.......
Old Nov 24, 2005 | 07:10 AM
02blkws6vert's Avatar
the taylor thundervolts are 10.5 i think, so if the ls6 wires are only 7 mm and the thundervolts are way bigger would there be any noticeable increase with the thundervolts? will the car still perform as good with the ls6 7 mm wires as it would with thundervolt or any other wires bigger than 7 mm?
Old Nov 24, 2005 | 08:52 AM
LS1-450's Avatar
Every time I find myself contemplating spark plug wires (advantages/disadvantages), I go back to the Magnecor web site. Many, if not all of the answers to your questions can be found there. Best of luck
Old Nov 24, 2005 | 10:29 AM
its not gonna matter. only way i see a benefit of a larger wire is if you are not running stock ignition. i went from 8.65mm moroso to 7 mm stock and it didnt hurt my track times one bit. im sure the better day to run waht the difference in time but i had my fastest trap with stock wires
Old Nov 24, 2005 | 12:28 PM
Weekend Racer's Avatar
I just replaced the plugs and wires (MSD 8.5) with header install and the wires fit fine and do not hit the headers if you bend the boot with slight pressure once seated on the plug. The red looks good too.
Old Dec 24, 2005 | 04:36 PM
maldo's Avatar
Originally Posted by Slammed99s10
Easiest way to avoid burnt wires are boot socks, taylor & dei both make great socks IMO. I'm currently running MSD wires w/ DEI socks:
If you do burn one or a few I'm sure MSD will replace it free of charge. I had one wire that was 2500ohms while the rest were 40, I called MSD directly and one of their tech's sent me not 1 but 5 replacement wires first class air mail for free.
Also the easiest way to get the #8 wire/plug is from under the car if you have headers, never changed them before with stock manifold but from the looks of it they would be a PITA.
P.S. No flaming on the bbk shorties, they came with the car when I bought it lol
Not sure why you would go though all that trouble putting those bulky heat shields when elitesparkplugs.com ignition wires incorporates the fire heat sleeves into wires already so much neater in my opinion and they are guarantee them for life (no other company gives that kind of guarantee …. Can’t beat that deal) Check out all the colors offered
Check out some of the wires and what they look like
Old Dec 24, 2005 | 04:39 PM
i dont see why anyone needs heat shields, the wires come nowhere close to anything that can burn them, just a way for places to charge more moeny
 Michael S. Palmer
Old Dec 25, 2005 | 01:29 AM
maldo's Avatar
Headers produce more heat then your typical exhaust manifold plus Elitesparkplugs.com prices for their wires are just as much as your typical wires replacement
Old Dec 25, 2005 | 07:36 AM
yeah but it wont make a difference in power, how much are those wires? i got my ls6 wires for 45 bucks
Old Dec 25, 2005 | 10:27 PM
BULLET99Z28's Avatar
Think about it, the wires are so freakin short, AND each spark plug has its own High powered coil, u will not notice any differnce in wires, the wire is only like 6 inches long, stock or GMPP will be just fine!
Old Dec 26, 2005 | 05:55 PM
  #32
maldo's Avatar
I think they are the same maybe a 5 dollars more .... plus they are 9mm wires and a life time warrantee can’t beat that for the price.
Old Dec 26, 2005 | 06:14 PM
  #33
weestro's Avatar
My taylors came apart on almost every plug when I pulled them today. I will never buy Taylor again!
WS6Firebird where did you buy your wires? I'm not seeing GM wires of any kind for less then $75...
Old Dec 26, 2005 | 08:27 PM
  #34
5 bucks more isnt too bad
i got my wires from gmpartsdirect.com, i also saw the same prices elsewhere but cannot find the sites
Old Dec 27, 2005 | 07:49 AM
  #35
2000 TAWS6's Avatar
I just put on a set of Autolite Professional 7mm wires, $ 35/set at Advance Auto.
Good quality and fit. Let's see how they hold up.
Old Jan 6, 2006 | 11:58 AM
  #36
maldo's Avatar
Cheap Chinese made wires.They will work for a while but the voltage from the LS1 coils will burn them up with in 30k.
Old Jan 6, 2006 | 05:05 PM
  #37
radz282003's Avatar
I don' t like the MSDs for anything except appearance. Yeah, they ohm a lot less, but, like it was said earlier, the wires are so short, and the coils so powerful, it would almost be a waste otherwise. Unless you were running a power adder or something like that. My MSDs started getting really loose on the plug end, after the first time I pulled them off. Yes, I pulled on the boot. They weren' t evens stuck to the plug porcelan ( can' t spell. ) The next time I try to install them, none of them click, and I couldn' t tell if they were on or not. Two sets. New sets. SAME thing. I had the GMPP wires off and on probably close to a dozen times, and it wasn' t until I found a crack, from heat, that I replaced them.
GMPP!!!
Old Jan 6, 2006 | 08:15 PM
  #38
weestro's Avatar
Anybody have any experience with Belden that Napa sells? 7mm, lifetime warranty, seem solid...
Old Jan 6, 2006 | 08:40 PM
  #39
Full-Force's Avatar
I replaced mine with MSD 8.5 only because one of my stockers were cracked open. The MSD boots are a little long and the #3 boot does come kinda close to the Pacesetter header tube. The MSD wires look and feel like good quality, alot better than any OE design. The boots and wires are real tight and firm fitting. I dont think they will come apart very easy.
