View Poll Results: Which Manifold??
LS6
95
85.59%
BBK
16
14.41%
Voters: 111. You may not vote on this poll
BBK vs. LS6 (Intake Manifold)
Old Dec 16, 2005 | 10:59 AM
  #121
Redneck Z's Avatar
QUOTE: I mean would you not use one of these intakes because they're made from aluminum?
Exactly.............Thats why it's heavier and suffers from heatsoak, and the reason I won't use one.
Old Dec 16, 2005 | 11:03 AM
  #122
technical's Avatar
I'm guessing you didn't click the links ??
  #123
slayer6x6's Avatar
Ive seen a few custom sheet metal LS1 intakes that were made strictly for racing purposes. Why would they be using aluminum if heat soak is costing that much HP?
Old Dec 16, 2005 | 11:13 AM
  #124
Cephiros's Avatar
http://www.katechengines.com/street_...s/DSCF0584.JPG (just the TB's are Al)
http://www.mycylo.com/(23sjl1eedhmcc...e.aspx?id=4999
http://users3.ev1.net/~black_ops/aus/dsc00037.jpg
no, i woudlnt use one fo those intakes for the pure lack of filtration
because they cant afford the tools it would take to mold a custom composite intake?
Old Dec 16, 2005 | 11:19 AM
  #125
technical's Avatar
The second one (Harrop Hurricane) does have more pieces that aren't shown. Two boxes that connect to inlets and ultimately air filters.
http://www.harrop.com.au/products/intake_systems.html
Old Dec 16, 2005 | 12:02 PM
  #126
Redneck Z's Avatar
Because heatsoak doesn't matter on a strict racecar, and won't cost them any hp. You can ice down the intake between runs. It won't matter on your streetcar either if you want to ice down the intake at every stoplight.
Old Dec 16, 2005 | 12:35 PM
  #127
DRGnFLYZ28's Avatar
BINGO!!
They do look bad-*** and I'm sure they perform well too.
Lots of good info in this post. For me, running an all aluminum LS1 makes me want to keep it as cool as possible.
Old Dec 16, 2005 | 12:36 PM
  #128
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Comparing those multi- TB intakes to single TB manifolds is like comparing apples to oranges.
Old Dec 16, 2005 | 12:43 PM
  #129
technical's Avatar
Yeah, but I really want one.
Old Dec 19, 2005 | 12:20 PM
  #130
2001whiteSS6spd's Avatar
Just to let you guys know they just had a test on the BBK intake, 80mm TB, and cold air kit in CHP feb 06 edition.
Old Dec 19, 2005 | 04:27 PM
  #131
TPiS's Avatar
Tenured Member
Default Aluminum Vs Composite
There is no contest, The LS-6 or the FAST are always more powerful. we just finished a 13 manifold test for Street Thunder magazine. The aluminum manifold in that test was soft every where, by about 5lb ft. and 10 hp.
The only reason to used the aluminum intake is if you want to polish the intake. We offer two different versions of the LS-6 intake, Our oval entry 75MM by90MM and Our 90MM entry and we have the throttle bodies to go with them.
Myron C
TPIS 952 448 5330
Old Dec 19, 2005 | 06:09 PM
  #132
Redneck Z's Avatar
Myron C
TPIS 952 448 5330
Well, there you have it! I guess there's nothing more to debate.....
Old Dec 19, 2005 | 06:27 PM
  #133
v8hunter's Avatar
Myron C
TPIS 952 448 5330
How about a quick summary on the results of the test...I know we would all love to hear the results.
Old Dec 19, 2005 | 07:07 PM
  #134
jclz28's Avatar
Anyone ever port one of the aluminum manifolds then have it ceramic coated? Does wonders for reducing external header temps because it is such a good insulator, I would assume it would work to reduce intake air temps when the manifold temp is high.
I am also surprised there is no attempt on those 'high buck' aluminum manifolds to thermally isolate the runner and throttles from the cylinder heads.
BTW, one main advantage of magnesium is its higher specific heat. It will have a lower temperature rise for a given amount of heat input, compared to aluminum. As said, it is also a lousy conductor of heat compared to aluminum.
Jim
Old Dec 19, 2005 | 07:17 PM
  #135
Cephiros's Avatar
Jim
by having it ceramic coated, unless you mean the inside of the intake, and not the outside, it would make the incoming air that much hotter, it isnt the outside temp of the manifold that does the damage.
Old Dec 20, 2005 | 09:20 AM
  #136
technical's Avatar
...The aluminum manifold in that test was soft every where, by about 5lb ft. and 10 hp.
Was it the BBK SSI intake?
Old Dec 20, 2005 | 05:47 PM
  #137
SUX2BU's Avatar
They said they did a 13 manifold test so i'm sure that included the bbk. can you name 13 intakes other than the BBk?
Old Dec 20, 2005 | 06:44 PM
  #138
technical's Avatar
I can't name 13 intakes including the BBK.
If I count the LS7 and both combinations of LSX...
LS1, LS2, LS6, LS7(doesn't fit), LSX 78, LSX 90, Weiand, Holley, Truck intake, BBK, GM (carb), Edelbrock (carb)
I'm still short one...what else is there? Are the Holley and Weiand really the same intake?
Old Dec 20, 2005 | 07:57 PM
  #139
solocam's Avatar
they just done an article in Hot Rod and the Fast 90/90made over 30 H.P. on a 346 inch ls1.
Old Dec 20, 2005 | 08:07 PM
  #140
solocam's Avatar
the ls6 is worth 12 to 15 over ls1 the fast 78/78 isworth about 20 over ls1 and fast 90/90 is worth over 30. Id bet the aluminum intakes are really comparable to the ls1 when heat soak sets in.
