Anybody know size of I pipe on v-6 camaro
Live in ca and cant find anybody in my area to run x pipe duals from the cats on back over axel.If the v-6 model uses a 2 1/2 I can pick up to i pipes from a salvage yard.once I am over the axel I can weld up the rest myself.
^^ that is the correct size
you can run 2 1/2 inch that the cat-back I have if you want a 2 1/1 inch I-pipe only you would have to buy a adaptor piece for each end that will allow you to run bigger then stock pipes any good exhaust shop to do them for you..
