160 t-stat
Old Dec 8, 2005 | 12:00 PM
blackbird00's Avatar
Default 160 t-stat
I just installed the hypertech 160 T-stat. And my temperature gauge still reads 210 is that normal or should it be lower.
Old Dec 8, 2005 | 12:05 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Perfectly normal for a '99-'02 car. Your gage will always read right about 210 any time coolant temp is in the 175-230 range.
A scanner is needed to see real coolant temps.
Either way, the only drop in temp you will see is at cruise until you reprogram the fans to cut on sooner (or get a fan switch).
Old Dec 8, 2005 | 12:08 PM
Nasty N8's Avatar
As he said and also what most do not realize is the T-stat is reverse flow so the temp it sees on the back side is about 15 degrees hotter where the temp gauge sender is. These cars run there best a little warm 190* is optimal.
Nate
Old Dec 8, 2005 | 02:52 PM
Thanx Ya I Bought Teh Hypertech Power Programmer And It Has An Option To Turn The Fans On With The 160 Degree T-stat What Temp Should I Set The Fans To??
Old Dec 8, 2005 | 02:57 PM
BULLET99Z28's Avatar
Yeah, I installed a 160 tstat, and went in with hptuner and I think I set the 1st fan at like 175 and the 2nd fan temp at 182-4, somewhere in there. is this to cold for the motor to run at full potential, should I wwarm it up a little, and will runing at these temps cause it to run to rich? thanx for any info
Old Dec 8, 2005 | 03:06 PM
bshell's Avatar
I have the Hypertech 160* as well. Here's what my fans are set at:
Fan 1
ON: 184
OFF: 175
Fan 2
ON: 194
OFF: 185
These are the settings I was giving when I bought the car (verified with HPTuner). In traffic (common in HI) my temps run in the mid to upper 180s.
Old Dec 8, 2005 | 07:33 PM
RPM WS6's Avatar
Using an HPP3, you only have the option of setting the fans to the preset HPP ranges for each stat option. It gives you these ranges in the HPP manual. You can't set exact temps yourself with it. You'll either have to use the 160 or 180 option, whichever you prefer.
