what is the best antifreeze?
Old Jan 1, 2006 | 11:53 AM
BLKY2KZ's Avatar
My question is, will regular antifreeze hurt the engine?
Old Jan 1, 2006 | 12:47 PM
ArcticZ28's Avatar
The "green stuff" is more prone to oxidizing the aluminum in our engines. Hence, Dexcool's main purpose. Just use it.
Old Jan 1, 2006 | 01:36 PM
Pwebbz28's Avatar
Dont you mix Dexcool with water neways?
Old Jan 1, 2006 | 01:53 PM
DanZ28's Avatar
Yes you do.
Old Jan 1, 2006 | 03:19 PM
LawmanSS's Avatar
Originally Posted by LS1-450
GM is changing to Zerex G-05 anti-freeze/coolant as the factory fill.
Can you elaborate on this...according to the Valvoline website, not only is Zerex G-05 not approved by GM, but it's not even recommended by Valvoline...
From the Zerex FAQ:
Can you use Zerex G-05 in a GM Vehicle?
While one can use Zerex G-05 in a GM vehicle, Valvoline recommends that you use a GM DEX-COOL approved formula in a GM vehicle under warranty.
Old Jan 1, 2006 | 04:46 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Personally, I would just stick with Dexcool. I've never had any issues with it.
Not sure when/if GM plans to change the factory fill, but as of '05 they still came with Dexcool.
